E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
#26
well...did you swap out the plug as well to isolate the cylinder from the plug from the coil??
and what were the readings?? df
I did swap the plugs as well as the coil to the next cylinder.
Even though all plugs are new bosch plugs. Reading still says cylinder 5 misfire. :/ |
#28
ok, so if the coil has been moved to a different cylinder as well as the plug, then you are looking at something in the cylinder that is causign the misfire.
my initial feeling is a bad valve. hove you done a compression test?? i suggest doing a static and running compression test to the cylinders. the first 'puff' of the static compression test is a pretty good indicator of what the running compression should be, so pay close attention to that. it mught be best to have a helper. the running test only needs to be a few seconds for each cylinder, but can point to a potential problem within the cylinder. also a leakdown test is a good test to do, but if you are not an experienced diy'er it's sorta kinda a difficult test to 'get it right' and not still have questions. plus you need an air compressor. df
This is the result of the reader real time eng. rpm:
And this morning the car started making this sound when accelerating: Quote:
#30
I did some research and have an understanding of the compression test. I will do that today, ill head back here with my findings. Thanks.
This morning the code finally came up. Cylinder 4 misfire! Even though its on 'PENDING' So, does this mean the coil went bad? Since all plugs are new? If so, do I need to replace all 6 coils at once or can I replace a single coil for now? Also, a set of 6 Bosch fuel injectors are on the way. Since the one's its got on look pretty old, they might get clogged soon. The previous owner didn't take care of this thing at all. Most of the parts I've replaced are rusty old oems. Like it was a b**** to take out the control arms n bushings. |
#32
Replacing one coil pack at a time is fine.
When it absolutely, positively, has to be destroyed overnight! OohRaah!!! U. S. M. C. Semper Fidelis
#33
Good news 2.0
The shaking finally came to an end. And the car now runs like a beast again 0-60 in 7 secs ![]() Replace both new emission relays for new ones, replaced the faulty coil for a new bosch coil, bought the two downstream o2 sensors they should be in my mailbox soon. I spent quite some cash on all this stuff and tools I bought. So my girlfriend was like, oh couldn't you just have taken it to a mechanic and spent around the same? And then it thought of you people and replied; You have no idea what you're talking about. Thanks a lot everyone. I still need to fix the incomplete monitors to pass Chicago's emission test: 1. Catalyst Mon. 2. Evap System Mon. 3. Sec Air System Mon. 4. Oxygen Sensor Mon. 5. Oxygen Sensor Hrt. So if anyone knows how, your help is greatly appreciated. And youre awesome. |
| Bookmarks |
| Tags |
| camshaft, idle, o2, positioning sensor, shaking |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
