Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E90/E92/E93 M3 (2008 - 2014)
4th generation E90 M3 sedan, E92 M3 coupe and E93 M3 convertible. The last of the naturally aspirated M3s, powered by a 4.0 liter V8 making 414hp and 295 lb-ft of torque.
Old 03-26-2012, 04:34 PM
Slave2Miles Slave2Miles is offline
Mein Auto: 2014 911S, 2016 X5 50i
Auto start / stop not working
Not that I really care that much, but my Auto start / stop has never seemed to work. Is there anything I need to do other than turning it on to make this feature work? My car is a 6sp so perhaps that has something to do with it.
Old 03-26-2012, 05:20 PM
ksoze ksoze is offline
Mein Auto: 2011 E93 M3
According to the BMW web site, "The Auto Start Stop function automatically switches off the engine when the car is at a standstill and in neutral, then restarts it as soon as the driver presses the clutch pedal again."
2011 E93 M3 Convertible JB/FR | 2002 E46 M3 Convertible | 2002 E53 X5 3.0 | 2000 E39 540i | 1998 E36 M3 | 1988 E28 M5 | 1987 E28 528i
Old 03-26-2012, 05:57 PM
logicalthought logicalthought is offline
Mein Auto: 2013 Boxster S
Just FYI, the default setting is "off," which is the state it's in when its little switch on the dashboard is lit. I leave mine off because I suspect that the constant stop-start could prematurely wear the battery and maybe even the starter. Eventually, this will be handled by either a second, designated battery or an ultracapacitor, but I don't think the system on the M3 has either of these.
Old 03-28-2012, 12:22 PM
Jamze132 Jamze132 is offline
Mein Auto: 2014 228i
The system isn't operable unless the engine has reached operating temperature and it's above 37f I believe. I might be off base here...
Old 03-28-2012, 12:45 PM
solstice solstice is offline
Mein Auto: 2015 F80 M3
I tried it twice by just pushing the button. It works and I hated it. Thanks BMW for making it off by default, please do the same on the new M3.
Old 03-29-2012, 05:39 AM
335i 335i is offline
Sup3rman
Mein Auto: '11 E90 AW M3/ '11 AW X5d
I've used it on occasion in heavy traffic where there are longer periods of not moving. Also works well in a drive thru when there is a heavy wait, but I don't use it daily. I can appreciate it in those special circumstances, but don't have a need for it daily.
FYI, it will automatically start the car up/not engage if the heat/air varies from the auto-climate setting (AC needs to kick on, etc.).
2011 ///M3 Sedan Alpine White/Bamboo Beige/Piano Black ED 9/16/2011
2011 X5d Alpine White/Cinnamon/Bamboo PCD 6/21/2010
2007 335i Coupe - 6MT Alpine White/Saddle Brown ED 5/23/2007 (retired)
ED Trip Report W/ Pics (And Engagement Story/Pics)
Old 03-29-2012, 08:31 AM
NASA43's Avatar
NASA43 NASA43 is offline
Make Their Ass Quit!
Mein Auto: 2008 M3
I had no idea they implemented the Start/Stop feature on the M3.
2008 M3 Sedan, Silverstone II, Fox Red Extended, 6MT
Old 03-29-2012, 08:41 AM
The good news is that they defaulted it to OFF, unlike the F10 which defaults to ON and needs to be switched off at every start-up.
Old 04-12-2012, 10:08 PM
MRV99 MRV99 is offline
Mein Auto: 2011 M3 DCT
The auto start/stop does not use the started to restart the engine. The engine uses itself to start the engine and is done by sparking a compressed cylinder. Read up on it, pretty neet
12 X5 50i Sport
11 M3 DCT
11 X5 50i (lemon)
-- SOLD --
08 550i M-Sport
04 BMW 545I sport
07 BMW X5 4.8I sport
02 BMW X5 4.4i sport
01 BMW 540I M/sport
00 SL500
97 SL500
Old 04-13-2012, 04:36 AM
Where did you see this? In a quick Google search re how it works, all I can find is this, which clearly references the starter:
"The Auto Start Stop function is coordinated by a central control unit that monitors data from all relevant sensors, the starter motor and the alternator. If necessary for comfort or safety, the control unit will automatically restart the engine: for example, if the vehicle begins to roll, the battery"
http://www.bmw.com/com/en/insights/t..._function.html
Old 04-22-2012, 05:29 AM
TqIsQuick TqIsQuick is offline
Mein Auto: 2012 535iX
...and there's a little jerk when it comes back to life, it's not compeltely hidden from the passengers. That said, we always turn it off as soon as the car is running. Have had the car for less than two months and can say this is one big BONER of a 'feature'.
My wife drives through a very urban area to/from work each day and is scared to death that the car won't restart one of those times. Aside from the wear and tear factor on the car (and there has to be some), the little lurch is pretty annoying on a $66,135 car (if you forget to turn it off at initial start up). Since it is switched, the switch must a fuse (or a relay) that will disable the feature...there are several fuses attributed to start/stop and I guess I'm just going to start pulling one by one and see if I can isolate where/how the switch is powered.
Old 04-22-2012, 06:22 AM
Originally Posted by TqIsQuick View Post
... we always turn it off as soon as the car is running.... Since it is switched, the switch must a fuse (or a relay) that will disable the feature...there are several fuses attributed to start/stop and I guess I'm just going to start pulling one by one and see if I can isolate where/how the switch is powered.
You shouldn't have to do that, as the default setting every time you get in the car should be "off"; i.e., when the little on/off button is lit (which mine is whenever I start the car-- with the key, of course), the feature is NOT on, and if I wanted to use it I'd have to manually turn it on by pushing that little button and making that light go off. So unless you'd want to try to pull the fuse just because the light annoys you... But, of course, that's why they make black electrical tape!
Old 04-22-2012, 07:05 AM
not on mine...
...well its default is 'on' in our car. Pushing the button to 'disable' the feature illuminates the yellow bar light below the switch. The light is not illuminated and auto start/stop is enabled/fully functional after each time the car is shut down. Maybe as of a certain VIN it's 'always on'?
I'd LOVE for it to be an option to use vs. having to switch it off at every use.
thanks
Old 04-22-2012, 07:12 AM
...well its default is 'on' in our car. .. Maybe as of a certain VIN it's 'always on'?
Wow, that's interesting. Well, my car was build in May 2011... Maybe yours is newer?
Old 04-22-2012, 07:47 AM
kscarrol's Avatar
kscarrol kscarrol is offline
Mein Auto: 2011 E90 M3 + 1997 Z3 2.8
Tq has an F10 535 and I've heard the default is on for the 5 series...
Old 04-22-2012, 07:50 AM
The F10 defaults to ON, mentioned in several posts up. If TQ has an F10 and is posting here on the M3 board for that info, he is going to get confused.
Old 04-22-2012, 08:19 AM
kscarrol's Avatar
Agreed but he lists a 2012 535xi as his "Mein Auto"....
Old 04-22-2012, 08:22 AM
The he is "geschraubt" as far as the auto start/stop
Old 04-22-2012, 09:18 AM
...yes, wrong board. I chimed in as it 'torques' me off I guess. Sorry to poach (and the car is new, new; delivery on 3/3/12).
thanks all -
Old 04-22-2012, 09:34 AM
kscarrol's Avatar
No worries! Just want to make sure you understood the difference... And I'm with you, would not be happy with the default being on in my car. Surely someone can code the feature to default to off.
Here is a thread in the F10 forum to get you started:
http://www.bimmerfest.com/forums/sho...ght=start+stop
Old 04-23-2012, 12:04 AM
Jim in Oregon Jim in Oregon is offline
Mein Auto: 2009 E92 M3 Coupe
European M3's default on.
Old 04-23-2012, 07:22 PM
PhillyNate's Avatar
PhillyNate PhillyNate is offline
BMWCCA Member #405750
Mein Auto: 2011 E92 M3 ZCP
Why on god's green earth, no pun intended, would this feature ever default ON in ANY model or on ANY continent? Just not understanding this company these days.
2011 Alpine White BMW M3 Coupe 6-speed Manual w/ ZCP.
2008 Alpine White 328i Coupe 6-speed Manual/ BMW Performance Exhaust/ M6 Wheels. (Retired)
Future owner of a Jetson's fold-up briefcase car. So I can TRULY park worry free.
"what I'm driving here...is an ending." Jeremy Clarkson
Old 04-23-2012, 08:04 PM
Apparently our beloved representatives has decided that a manufacturer can not use start/stop in their mpg testing unless it's defaulted to ON. Not sure how true this is but that's the rumour. Still, please leave the M cars to default OFF BMW and make up the savings on the non performance models. Actually make the whole function optional on the Ms.
Old 04-25-2012, 05:23 PM
Kurt_OH's Avatar
Kurt_OH Kurt_OH is offline
First Timer
Mein Auto: Me: M3; Her: 335i
2011 E90 M3, delivered Nov 7th, 2011 (Euro Del). Auto start is disabled by default. I've never turned it on, so I can't report on how it works, just that it has NEVER activated in my car.
I just love how a 4 year old car/design is STILL the benchmark which other automakers aspire to reach. Still winning comparisons . Still very much in the conversation. Is the E9x M3 a legend? You bet your @ss it is.
