E46 (1999 - 2006)
Old 03-29-2012, 08:58 AM
calibmw323 calibmw323 is offline
Mein Auto: 325i
Not good. how bad is it??
ok I have a 2003 325I with 98,041 miles and for a while now the front tires have been real shaky and now I have the brake sign on the abs sign on and the tire traction sign on. It shakes a lot on turns give me an unpleasant ride but I'm not sure what it is I know its not the rims I just had them balanced and aligned so what could it be and where's the best place I can get the parts and it fixed thanks a lot I know you guys will help me out
Old 03-29-2012, 10:56 AM
Cotwell Cotwell is offline
Mein Auto: 2002 330ci
First put the car on jack stands. Grab the wheel and give it a 3-9 and 12-6 check (checks bearings and steering). Then get a hold of each suspension component (including rotors and calipers) and give it a good shake test. From there you may find your problem... hopefully
Old 03-29-2012, 11:20 AM
Mein Auto: 325i
If the wheels are off the ground the wheel will move a can shake it pretty easily and my steering wheel moves as well is that suppose to happen?
Old 03-29-2012, 12:39 PM
Don't shake the wheel with all you got haha. Just enough to where you can here a slight clunk or whatever the noise. And the there should be a little but tight movement while checking 3 and 9 because of the steering. If there is a clunk at 3 and 9 then it's more than likely an outer tie rod end. I could be wrong though.
Old 03-29-2012, 07:47 PM
Mein Auto: 325i
Hahaha I'm not shaking it with all my force ain't going all hulk on it lol I didn't listen for that ill be sure to do that when I'm checking it. They had told me to fix it it would cost like 700 but idk if there just tryin to screw me over
Old 03-29-2012, 11:15 PM
What did they say they were going to fix/replace?
Old 03-30-2012, 06:11 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Sounds like control arm bushings to me. The lights on your dash are probably from a bad wheel speed sensor.
Old 03-30-2012, 07:40 AM
Mein Auto: 325i
I don't remember what they said was the problem exaclty but the contol arm bushings does sound familiar I think that might be what they said was the problem. A bad speed sensor lights up all four signs? Thanks for the help guys
