Old 03-30-2012, 06:24 AM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
o-ring at coolant temp sensor
Hi,
While I had the control arm bushings replaced on my '06 530i, yesterday, I noticed coolant leak on the coolant return hose [at the radiator return line]. I looked from above and I saw traces of coolant on the coolant temp sensor as well. I am thinking the leak is from the o-ring on the temp sensor. It doesn't look like o-ring is available separately. Anyone replaced just the o-ring on the coolant temp sensor?
This picture is taken from under the car.
Old 03-30-2012, 09:43 AM
boramkiv's Avatar
boramkiv boramkiv is offline
Propellers Up Front
I dont think the oring is sold separate from the sensor. I looked all over for it and even according to realoem its one piece even for other BMW models. Most bmws use the same exact sensor and dirt gets in there (somehow) and ruins the oring causing a leak. I was able to get a perfect size oring from a local hardware store. The sensor itself is about $25 if you want to go that route.
Old 03-30-2012, 09:58 AM
pcy pcy is offline
boramkiv, thanks for your feedback.
I hate to throw away good working temp sensor just because of bad o-ring. Do you happen to remember the size of the o-ring you bought at the store?
Old 03-30-2012, 10:22 AM
boramkiv's Avatar
Propellers Up Front
I cannot remember. I took the sensor in with the old compressed oring to a Tayor's home center. They have a huge oring inventory. It didnt cross my mind to remember the size I just grabbed three of them. It was a lucky guess for me.
Old 03-30-2012, 10:26 AM
boramkiv's Avatar
Propellers Up Front
Check this out:
http://www.bimmerfest.com/forums/sho...d.php?t=474027
I saw this afterwards. I have to admit you gotta love bluebee!!
Old 03-30-2012, 11:37 AM
pcy pcy is offline
Thanks for that info.
I went to BMW dealer to get that o-ring, they didn't have that o-ring in stock. I ordered one.
