Old 03-30-2012, 01:48 PM
tturbonegro tturbonegro is offline
Mein Auto: audi quattro, f350, e90
Key fob battery ?
Doors aren't unlocking untill you hit the button like 5 times and have to be real close so I'm assuming the battery is dead..
What size battery does it take and what's a good way to pop the key open?
Old 03-30-2012, 02:49 PM
Mein Auto: 2004 X3 2.5i
Does you 2nd. key work any better?
If not, could be a receiver problem.
If the other key works O.K., then there are a few possibilities for the bad one before the battery is blamed.
Such as a gummed up button or previous water damage to it (under a previous owner?).
If keys are not rotated in use, the rechargeable battery can reportedly get in a discharged state where no amount of recharging will help.
And it does take a decent drive of some distance to recharge anyway.
In my experience, the keys can take a lot of recharging cycles, or OTOH, extended lack of use, without giving any problem.
If needed, battery replacement is technically possible as a DIY, but could be challenging, and your key won't look too good afterwards.
See:
http://www.bimmerfest.com/forums/sho...d.php?t=449434
http://www.bimmerfest.com/forums/sho...d.php?t=582138
Old 03-31-2012, 08:57 AM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
Too bad that very good DIY with photos on changing the battery in the key is lost somewhere. As I recall it was a number of years ago and there were some good tips on how to do it with the least "mess" on the key case.
Old 03-31-2012, 09:56 AM
There are quite a few youtube videos of the procedure, but they don't inspire much confidence.
This is one of the better ones:
The point is that the battery may not be the problem.
It could be the switch contacts or the circuit board itself.
One of our forum members recently posted that they solved the problem by just cleaning the shaft of the key.
So it's best to first make sure that you have given a key the best chance of recharging properly before taking a knife to it.
Old 02-24-2013, 02:27 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
This is the closest key replacement battery.
For how to pop the key open, see:
- How to replace the old-style BMW square key battery (1) (2) & how to replace the rubber key pads in the square keys (1) (2) & what the red LED indicates on the old square key (1) & what can go wrong with a key and where to send it for repair (1) (2) (3) (4) & what battery to use in the new style 2000+ BMW E39, E46, E53, E85, etc. diamond key (1) (2) (3) (4) (5) (6) (7) & youtube videos of diamond key repairs (1) (2) (3) & a square key to diamond key retrofit and transponder swap (1) (2) (3) (4) & diamond key to square key retrofit questions (1) & how to recharge your key out of your BMW and how long that key will last in the drawer before it needs that off-the-car recharging (1) & the details on swapping the BMW diamond key transponder (1) & the proper diamond key initializing or programming sequence (1) (2) (3) (4) (5) (6) & what to do if your only key is locked inside your bimmer (1) & a description of the various types of BMW Remote, Illuminated, Spare/Wallet, & Valet/Service keys (1) (2) & a list of diamond key EWS, FZV, & DWA functions (1) (2) & all about the 10-key limit to programming your own keys at home (1) & a description of the ignition key ISN (individual serial number) ten-second rule (1) & what to do if you lost your only diamond key (1) or what to do if your BMW key was stolen (1)
Old 11-03-2014, 06:30 PM
cefiro97 cefiro97 is offline
Mein Auto: 2004 BMW X3
Hi bluebee,
I want to buy a 2nd key for my 2nd-hand X3 (the previous owner has handed me only 1 key), but how to program EWS transponder chip for it to recognize my car? Tks.
Old 11-03-2014, 08:18 PM
joylove joylove is offline
Mein Auto: 08 e83 LCI
You must buy a key from the dealer. Programming the EWS is not supported.
