Old 03-31-2012, 06:45 PM
sak_916's Avatar
sak_916 sak_916 is offline
Mein Auto: 2005 BMW 745I
HID Fog light installation
Hey guys, I have the HID conversion kit from DDM and was wondering if anyone knows exactly how to do the installation.
Thanks in advance!
Old 03-31-2012, 11:20 PM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
If it's like the ones that I've done, you take the clip off entirely that holds the existing bulb in place (using pliers or a flat head screwdriver), and you hold the new bulb in place by bending over the pieces the clip attached to, pinching the new bulb in place.
To get the wires through the back cover, you drill a hole through it about the same size as the skinniest part of the rubber grommet on the new setup and then caulk around the grommet once in place.
You should be able to just plug the rest in.
On the several that quarterto8 and i have done, we've found that you can securely and easily mount the ballast to the top of the brake air duct on each side using a layer of double-sided duct tape from Lowes / Home Depot on the entire underside of the ballast.
Hope this helps!
Sent from my ADR6425LVW using Bimmer App
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 03-31-2012, 11:43 PM
sak_916's Avatar
Hope this helps!
Ya man this helps a lot actually. I will get to it after I'm done lowering the 7 just wanted to know for sure since after a saw the cables and stuff I was a bit confused :/
Thanks again for the info Keif
Old 04-01-2012, 04:21 AM
N62B44 SGM's Avatar
N62B44 SGM N62B44 SGM is offline
Mein Auto: '05 E66
Hey Sak, I was going to go off of these when I get my car back...
http://www.bimmerfest.com/forums/sho...d.php?t=182154
http://www.bimmerfest.com/forums/sho...d.php?t=415684
Keif, what kind of caulk should be applied, all purpose? I think I have some for rubber laying around (used it on a rubber seal for a commercial fridge).
www.fquick.com/N62B44_SGM
2005 BMW 745Li E66 Sterling Grey Metallic / 35% Tint (windows) / 20% Tint (tails) / ACS Roof Spoiler / Interior & Exterior LED's / MTEC V3's / 6000K D2S /
DDM Tuning HID 6000K Fogs / BIMMERFEST license plate cover
Old 04-01-2012, 07:59 AM
JayVEE JayVEE is offline
Mein Auto: 02 745Li
Also when I did mines a while back I was getting flickering. I added a capacitor on each ballast and they've been great ever since.
Old 04-01-2012, 09:02 AM
sak_916's Avatar
Oh wow thanks for those links I have no idea how I missed those threads
Old 04-01-2012, 09:05 AM
sak_916's Avatar
I did get the resistors too, I will try to connect everything so I don't have to redo anything later
Old 04-01-2012, 09:09 AM
N62B44 SGM's Avatar
Mein Auto: '05 E66
You're welcome Sak . Let us know where you mount the ballast/error eliminator! After reading the threads I pulled the covers apart to eyeball everything and I was a little .
Old 04-01-2012, 09:17 AM
sak_916's Avatar
Haha yeah me too. I thought it was going to be easy but when I saw all the cables I kinda lost
Will try to get it done today or tomorrow.
Don't have much left to do, just this, install roof wing, put front custom license plate on, finish lowering and windshield 50% tint and that's it I think
Old 04-01-2012, 09:21 AM
N62B44 SGM's Avatar
Mein Auto: '05 E66
I'm using my phone to reply but I'll check on my computer. I think I have a link saved where they also explained the wiring. I think I already figured mine out.
Old 04-01-2012, 09:27 AM
sak_916's Avatar
Ok that would be great. I'm gonna go to the shop soon to see if I can get that done today
Old 04-01-2012, 09:28 AM
sak_916's Avatar
Oh and thanks so much man!!!
Old 04-01-2012, 09:34 AM
N62B44 SGM's Avatar
Mein Auto: '05 E66
Are you going for other stuff too? If it's just for the lights I'd say DIY but it's up to you. I'm wondering if electrical would work in place of the caulking, Keif, mentioned...
Old 04-01-2012, 09:35 AM
N62B44 SGM's Avatar
Mein Auto: '05 E66
You can even type in "DDM Tuning" in YouTube and people show how they plugged it all in.
Old 04-01-2012, 09:37 AM
sak_916's Avatar
Well the 7 is at my dads mechanic shop I'm not driving it now so he does all the work and I do all the small stuff
Old 04-01-2012, 09:38 AM
sak_916's Avatar
Oh cool I'll do that right now
Old 04-01-2012, 09:43 AM
N62B44 SGM's Avatar
Mein Auto: '05 E66
Here, best one I found...
Old 04-01-2012, 10:08 AM
sak_916's Avatar
That's actually very helpful. I think I got it figured out I just need to make sure I instal the resistor properly but I'm sure that should be clear after the installation
Old 04-01-2012, 05:04 PM
sak_916's Avatar
Hey what's up everyone. Just came out of the shop, finished installing the roof wing, front plate and interior led lights. Will post pix as soon as I get home.
Didn't have time to do the fogs today but I took some pix to make sure the connections are correct
Old 04-01-2012, 05:58 PM
sak_916's Avatar
ok so here are some of the pix of what I did today
installed front plate and roof spoiler
Old 04-01-2012, 06:01 PM
sak_916's Avatar
finished installing interior LEDs
I actually used UV leds on the side ones both front and rear and they look amazing, I posted a pic where you guys can see how colors look in the dark under UV specially white. Also the rest are regular white LEDs and they are really bright also posting a pic where you can see how much light they give
Old 04-01-2012, 06:03 PM
sak_916's Avatar
So here is the DDM HID conversion kit. I took individual pix and one all connected so if I made something wrong please let me know. Also where does the resister go?????
Old 04-01-2012, 06:35 PM
N62B44 SGM's Avatar
Mein Auto: '05 E66
I'm blown away, your car is gorgeous! I love your custom plate molding! Did you fab that up yourself? Great pics too! You're just on a roll...!
Old 04-01-2012, 06:46 PM
sak_916's Avatar
Thanks a lot bro I really appreciate it specially since it took me so long to get here lol about two mints without driving the 7
The custom plate was an order from eBay. It cost me $45 you can get any style or color combination you want (I liked the black on black one) if you want to let me know and I will tell you the seller so you can get it from him. You can have whatever you want up to 10 letters put on it.
Old 04-01-2012, 06:56 PM
N62B44 SGM's Avatar
Mein Auto: '05 E66
Sure thing, I would appreciate the details. More so, I was referring to your molding on the car itself how you have the plate set inside it. Did you custom make that trim piece? From what I see, your license plate fits/sets into the trim piece.
ID:	319463   Click image for larger version
