E36 (1991 - 1999)
Old 04-01-2012, 05:38 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Well this can't be good
Yep, another one of those threads. Need to lay out a plan.
1) Coolant Flush
2) Coolant Flush + Stop Leak
3) HG replacement (good time to get a thicker gasket...?)
4) Head rework
5) Head replacement
I'm hoping the problem is fixed before step 3, and definitely before 4/5.
What do you guys think?
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 04-01-2012, 05:48 PM
Corey Milne's Avatar
Corey Milne Corey Milne is offline
FixItFaster
Mein Auto: EuroS50B30, e83m54b30
I think its fairly obvious from the photo (unless your using some sort of thick yellow coolant I've never seen) that you have oil and coolant mixing. Most likely head gasket, if your unlucky perhaps cracked head. After you have confirmed that you need to pull the head, have it pressure checked, if it passes have the head re-surfaced and replace the head gasket.
Old 04-01-2012, 06:06 PM
petriej's Avatar
That is what I was afraid of. Should I even bother with steps 1 and 2?
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-01-2012, 06:21 PM
Mr Gusta's Avatar
Mr Gusta Mr Gusta is offline
Fireballs inc.
Send a message via AIM to Mr Gusta
Mein Auto: big turbo hellrot sedan
looks like a blown HG, how much boost are you at?
Turbo lag is just a headstart because the chase is more exciting than the win - Abraham Lincoln
Old 04-01-2012, 06:48 PM
petriej's Avatar
6-8psi
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-01-2012, 06:51 PM
Mr Gusta's Avatar
Fireballs inc.
hmmm seems weird... what blower are you on?
Old 04-01-2012, 06:54 PM
dc_wright's Avatar
dc_wright dc_wright is online now
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
DO NOT EXECUTE STEP 2!!! The stop leak crap is indiscriminate in that it will happily try to fill or plug any gap or small passage it can. It rarely solves any issue more than temporarily and then you'll have a hell of a time getting it flushed out of your system.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 04-01-2012, 06:59 PM
petriej's Avatar
VF S/C. Not sure which one, and I don't want to go out and check.
Roger that.
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-01-2012, 07:00 PM
Mr Gusta's Avatar
Fireballs inc.
if its a kit that flows more air at 6psi than a smaller kit makes at 11 the milshake makes sense
Old 04-01-2012, 08:04 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
any driveability issues?? overheating??
i always suggest confirming a with one of these...http://www.blockchek.com/
they all work the same, and are available from napa, and most likely other parts stores and online.
df
Old 04-01-2012, 09:48 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Damn Jared, sorry man. It looks like you'll be pulling the head... Perfect time to get a more durable head gasket and throw in some ARP head studs.
1998 BMW 328is
1966 Pontiac GTO
Old 04-01-2012, 10:48 PM
petriej's Avatar
df
Nope and Nope. I'm crossing my fingers I caught it in time to not have a warped or cracked head. I'll check out the kit. I had a couple of other suggestions to check for exhaust gases in the coolant, but I'm pretty sure it is oil. Definitely not using any of that waterless coolant of similar color or anything similar.
I know a thing or two about wrenching, but I've never done anything as complicated as a head gasket repair. Should I bother even trying it on my own? I have time and patience. Could be a good learning experience...
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-01-2012, 11:00 PM
hornhospital's Avatar
D'oh, You Kids!
If you have time and patience, go for it. You'll definitely learn a lot about your car...more than most. It's an involved job, but well within DIY status. There are many DIY write-ups on how to go about it.
Quotes to live by:
Old 04-02-2012, 01:10 AM
cmybimmer's Avatar
cmybimmer cmybimmer is offline
IM DA BES
Mein Auto: A rental
Never even knew you had FI lol
Hope its nothing TOO serious
-Usama
"The American Dream only makes sense if you're sleeping" - Lowkey
Old 04-02-2012, 01:37 AM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Oops.....all this time I thought it was Jason. My bad.
And I didn't realize it was blown either. Sweet!
Sorry to see that picture, how sad that must have been.
Sent from my LG Revolution 4G using BimmerApp
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 04-02-2012, 09:24 AM
petriej's Avatar
Yep. I was trying to keep it 'secret' for Bimmerfest, but oh well. Now my goal is to have her back up and running in time for the Bay Area caravan, if we're still doing that...
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-02-2012, 10:11 AM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
Sorry to hear.,
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
Old 04-02-2012, 10:30 AM
Jok15's Avatar
Jok15 Jok15 is offline
Currently overseas
Mein Auto: 2011 328i Coupe
There's a bay area caravan? Wah? I saw no such post anywhere :0
And sorry for the bad news :s
1997 Bmw 328i Vert - SOLD 3/25/2012
1992 Bmw 325i Sedan - ****ed 4/2/2012
2011 Bmw 328i Coupe 7/23/2016
Old 04-02-2012, 10:31 AM
petriej's Avatar
So if anyone local is bored, I'm accepting helpers for this job. I pay with food and drink (adult beverages if appropriate)
Right now I'm assembling literature. I already have the bentley manual, and I think the Pelican DIY article will be my main approach. My roommate has already expressed interest in helping. I'm trying to stay positive about this, but I know it's going to be expensive and frustrating.
I think the guys at MotorSpeed West will be my fallback, but I don't want to piss them off by breaking something. We'll see I guess.
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-02-2012, 11:26 AM
cmybimmer's Avatar
IM DA BES
Mein Auto: A rental
Dude id totally be down if you weren't a billion miles away and if I actually knew what I'm doing lol.. Never did a head gasket, currently helping out a friend replace his as practice (his blew twice).. how long do you think the car will be out of commission for? I'm sure you're going to try to get her up n running in a hurry lol
-Usama
Old 04-02-2012, 11:32 AM
petriej's Avatar
Well, I forgot I'm going to PR for 2 weeks in May, getting back right before Bimmerfest, so it looks like I have just over 1 month to get this all done. If I have to bring my X5 down to Pasadena, I won't be able to park with any of you guys
Vallejo to East San Jose is no more than an hour and a half... Maybe on a weekend? Probably not this weekend, seeing as it's Easter. I know it is going to be a long process, so I'll try to get stuff off the car during the week. Hoping to have the head off by the 14th. May need to buy some special tools it looks like.
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-02-2012, 11:35 AM
B1MM3R's Avatar
Jesse Moon Bayne
So they park all models together? like e36's together and e46's etc? J/W b/c I think me in the e36 and the misses in the x5 are driving to bimmerfest east.
Jesse
2001 330i DD
Old 04-02-2012, 11:38 AM
petriej's Avatar
I've never been, but from what pics I've seen there are two sections. Organized parking, and just regular FCFS parking for spectators and such.
GGC BMW CCA #443004
Join the BMW CCA!
Old 04-02-2012, 11:45 AM
cmybimmer's Avatar
IM DA BES
Mein Auto: A rental
Hmm I might be able to swoop by next weekend and offer the little help that I can lol. I mean, I've taken heads off cars before, but they were usually on scrap motors where I didn't care if I broke something in the process. And I know, been to SJ a lot back in the e36 days lol I was just teasing you
And they don't really separate you..they do manage parking so as long as you roll in as a pack, then you all will be parked next to each other. After an hour there are usually open spots around where you can move your car if you did happen to park far away .. But I still don't know if I'm going or not this year
-Usama
Old 04-02-2012, 11:52 AM
buellxb buellxb is offline
Mein Auto: 1997 328i
Hey man I just got this same diagnosis 2 days ago! Im in the same boat. Ordering parts today!
