Old 04-02-2012, 08:21 PM
rjgoss rjgoss is offline
Mein Auto: 99" 740 i
how to replace steering wheel?
I have a 1999 740I and I want to replace my standard steering wheel with a 3 spoke. How difficult is that? Is that something I can do myself? Don't work on cars alot but i'm pretty handy. Any tips on this would be great!
Old 04-04-2012, 01:14 AM
PETER NEWMAN's Avatar
PETER NEWMAN PETER NEWMAN is offline
Mein Auto: BMW 635 CSi BMW 730i E38
I needed to replace my steering wheel and I had a new wheel but i got my local main BMW dealer to do it as there is a mass of wires beneath the airbag unit, It was done in half an hour.
Old 04-04-2012, 07:53 AM
chrisn7 chrisn7 is offline
Mein Auto: 750iL
Not an especially good write up, but should give you some help:
http://www.bimmerboard.com/forums/posts/476495
The one thing he doesn't mention is to disconnect the battery. If you don't do so, the air bag light will display on the dash, and is a dealer reset.
Old 04-09-2012, 08:59 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Proceed with caution...the 1999 model year is split between the single stage airbag system and dual stage airbag system. You need to determine which type of set-up you have BEFORE you start shopping for a steering wheel.
If your car's build date is 3/99-up...then you have the dual stage airbag system. You have more options for either style of 3-spoke M steering wheels. The e38 & e39 use the same MFL steering wheels...and you can also use the e46 (dual stage wheels)
If your 99 was built between 9/98-2/99....then it has a single stage airbag system...and you need to look for single stage 3 spoke wheels from e39s or e36s built prior to 3/99...or you can shop the Euro market for e36/e38/e39 3 spoke single stage M 3-spoke steering wheels.
Here's my DIY (with battery disconnect warning ) for swapping my single stage 4 spoke wheel with a single stage 3 spoke steering wheel (from an e39). Since both wheels are single stage...it was a simple swap. If possible, try to get a wheel with the slip ring still attached...if the slip ring is unattached you can reuse yours but you want to be careful...you can see what happens if you unravel the innards in the link given above to Cliff's (visionbmw) DIY:
Q {BMW CCA Member #191509}
(SOLD)
Old 07-08-2014, 02:11 PM
HneDog HneDog is offline
Mein Auto: 1998 740il & 2010 750li
my steering wheel is completely stuck on there somehow and im not sure why because i removed the airbag, all the cables, and the center bolt and it wont come off any ideas? am i missing a trick? ive done it with the steering wheel locked and unlocked. any suggestions?
p.s. i pulled it so hard that the steering wheel actually started cracking down the middle and a gear puller or heating up the threads didnt help
1998 bmw 740il(current project) , 2010 bmw 750li
Old 07-12-2014, 11:44 PM
BMW750 BMW750 is offline
Mein Auto: BMW 750il 323ci
- A puller should do the trick.
Old 08-24-2014, 08:35 AM
leedelta13 leedelta13 is offline
Mein Auto: 1996 750il
Hello Everyone can you give me some insight? I want to change my steering wheel to a 3 spoke wheel. I have a 1996 750il . Can someone tell me what type of car year, model is should have the wheel from? single stage/ dual stage? Thank you in advance!!
Old 08-24-2014, 12:38 PM
sealbeach740 sealbeach740 is offline
Mein Auto: 2000 740iS, 2003 540iS
You have a single stage airbag, and you should replace it with another single stage airbag.
Everything you need to know is in Q's post above yours.
There are actually 2 types of 3 spoke steering wheels, but I'm guessing you want the 3 spoke with the fat airbag wheel that comes on the 99-01 sport e38s. You'll need to find that type of wheel/airbag from a different model BMW (maybe a 3 series?) that is a single stage airbag & still has the same steering wheel control buttons as your current wheel has. I'm not sure if they made that or not. You'll have to do some searching.....
2000 740iS. MKIV, 16x9, DDEs controlled by Euro fog light switch, reversed steptronic +/- pattern, paddle shifters, clear corners, Basslink, iPod video with stereo audio, TV tuner, gauge rings, ///M pedals, backup camera with 'on demand' switch, quad brake lights, Dinan engine & tranny software, windows/sunroof close via remote.
2003 540iS. MKIV, 16x9, PDC, CWP, TV tuner, backup camera with 'on demand' switch, paddle shifters, windows/sunroof close via remote, iPod video & audio.
Old 08-29-2014, 12:28 PM
FABOCH's Avatar
FABOCH FABOCH is offline
Mein Auto: 2000 BMW 740I SPORT
have u removed the 16mm center bolt off?
2000 740i Sport , Alpina 21`, Alpina Lip, Alpina Deco kit,Dinan 7,Dinan TB, DINAN CAI, DINAN Exhaust, Dinan Stage 5, Dinan 4/5 transmission, Dinan manifold, Highline individual interior,Eibach/Bilstein,Zimmerman Timing guides 08/13
Old 08-29-2014, 02:53 PM
BMWFatherFigure's Avatar
Old School
I hope that is a center nut you removed, rather than a bolt. Maybe you ae not 'deep' enough into the unit to remove the wheel at the moment. Maybe post a pix.
Current:
E38 Parts Car
Previous:
Old 08-30-2014, 05:31 AM
rsims5series rsims5series is offline
Mein Auto: Mercedes , BMW,Alfa
I did my steering wheel on a 98 740il the other day and it came off no problem???The hardest part for me was the t30 screws...
Current, 2002 530I,E320,, Past.2000 74Oil..Gone 323i,sold ONE 740il.Had 95,98 740IL,, also have ,,91 Alfa 164L,81 Alfa spider, 81 MB 380 SL...87 Milano,94 F348 spider.
Forget the Car Payment..
HTML code is Off
