Blower motor squeak - Page 2 - Bimmerfest - BMW Forums
Old 11-16-2012, 05:06 PM
flash_n flash_n is offline
Mein Auto: 745Li
Carfan thanks so much. I've been wondering for a few days what was going on.
My symptoms are as you describe. 3-4 second squealing noise from the passenger footwell when the car is cold in the morning.
The blower motor I replaced recently and it did sound alot different.
One more thing to add to the list...
flash_n
Silver 2004 BMW E66 / 745Li (DIYs):
ASK, Logic 7, blower, battery, guibo joint, active stabilizer bar bushings, diff oil, tranny sw update, vacuum pump gasket, window lift, a/c compressor, washer fluid reservoir, belt tensioner and deflector, crankcase vacuum hoses, crankcase vents, solenoid gaskets, headlight overhaul, ISM, hood lifts, driver mirror, sway bar end links, rear fog lamps, headlight washer, headlight vertical aim, VCGs
next up: P0492
Old 11-20-2012, 10:41 AM
7ELEVEN 7ELEVEN is offline
Mein Auto: 2002 745LI
Thanks for everyone that contributed to this post! This is on the long list of issues I currently have! ha ha
