E36 (1991 - 1999)
Old 04-06-2012, 07:30 PM
dc_wright's Avatar
dc_wright dc_wright is online now
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
The other box is the control module for your automatic transmission. Hopefully that didn't get flooded too!
I'd flush it using the same procedure I outlined above and then dry it out too.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 04-06-2012, 07:32 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
The TCU shouldn't cause a no spark scenario though.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
jonesin's Avatar
The Canadian Prick.
OP, do you know anyone local to you with a similar car that you could try their DME?
Old 04-06-2012, 07:37 PM
jeffw247 jeffw247 is offline
Mein Auto: 94 325i
That would explain why the trans light is flashing on the dash... I will pull that unit now and clean/dry it as well.
No check engine light and no spark. Dme looks clean doesnt appear to have damage BUT it was wet and i was trying to start it in the car wash parking lot right after it got wet.
Very unfortunately i do not know anyone around here that could help me test another dme unit /:
Sent from my SGH-T849 using Bimmer App
Old 04-06-2012, 07:41 PM
jonesin's Avatar
The Canadian Prick.
Mike aka Progress lives in OR. IIRC he's in Portland. He has a shop called Euro Edge, but they don't advertise much. I know he was working slowly on getting it net based, but I haven't heard from him in some time. Maybe try looking him up?
He's got an AA boosted Cosmos 328.
Old 04-07-2012, 03:45 PM
DinanM3e36's Avatar
DinanM3e36 DinanM3e36 is offline
WayTooFastWhitey
Mein Auto: Dinan BMW M3 e36
Makes me weary to drive thru a car wash, I usually use the stalls and bring my own microfiber sponge and soap with me (along with a whole bag of other cleaning polishing agents), going to check my vents now but I'm pretty sure they are clean....
At least your key isn't chipped or you would have to find a red label or go to the stealership
eBay is prob your best cheapest way to go, make sure you get the exact same one
Old 04-07-2012, 10:12 PM
clockworktech clockworktech is offline
Mein Auto: e36 325i
If you open the DME, dry it and you still get the same, you may need a new one (I got mine for $85 on eBay). I got similar results when mine got wet and corroded. It killed me figuring it out, and I took everything apart troubleshooting it. When I tested for spark using a screwdriver and then a real spark tester, I got nothing. When I tested with started fluid (bypassing the MAF), it backfired and popped, so i knew I had spark, but no gas. FYI, if you do the starter fluid test and it backfires, bear in mind that it will blow off your vacuum lines under the intake manifold, so when you do get it working, it will run like hell until you put it back. Do you hear the fuel pump spool up when you turn the key? it's a pretty distinct sound from under your rear seat, so if you really hear it, it's not really running (I still had fuel pressure in the lines for some reason though). I never in a million years would have blamed the DME, but it really was.
Old 04-07-2012, 11:09 PM
norcal_baller norcal_baller is offline
Mein Auto: 92 BMW 325is
where is this dme located? and where are the cowls that i need to clean out?
Old 04-08-2012, 09:28 AM
dc_wright's Avatar
Look at the photo fig 2 in the DIY to see the cowl drain. DME compartment is above and to the left (not shown in the fig 2 photo).
http://www.pelicanparts.com/bmw/tech...DME-Repair.htm
Old 10-07-2015, 11:00 AM
BMWK75s BMWK75s is offline
Mein Auto: 1998 323is
This worked for me!!! My DME was totally soaked. I removed the DME cover. I did the alternating rinses. Also, I had a can of "electrical contact cleaner" and used that for one of the rinses. I had started the car and run it 4 times before I got smart and took out the DME to fix it. Thank you so much.
Originally Posted by dc_wright View Post
You'll need a several gallons of distilled water and similar for the alcohol. You want to IMMERSE the DME or the DME boards and move around in the water the mix the soap and dislodge it. Remove the unit, let any water drain, immerse the unit in the alcohol and move it around to mix any remaining water with the alcohol.
Discard the original water and alcohol and start with fresh and repeat the above process.
Each time you do the the soap dissolves into solution and each time you repeat the process more is removed. By the time you've done this 8-10 cycles little if any soap is left.
