BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great! |
#26
ok,,,,makes sense
#27
2009 BMW 335D 2005 Chevy Silverado Duramax Diesel 2008 Polaris RZR |
#28
One of my friends has a F350 dually that is the same year as my F250. He bypassed the EGR and coolers for it then did the programming for the ECU to accomodate for that. He gets the same mpg as I do when doing 80-85 on extended runs EXCEPT he is pulling a good 20k lbs when doing that. It helped out things a lot on his truck, if I have a second EGR problem then I am bypassing it on my truck since it is clearly under no warrantees now.
--Aaron |
#29
hmmm egr bypass.... http://www.ebay.com/itm/160776165019 sounds like an ebay item.
#30
@Snipe Houston(err BMW) we HAVE a PROBLEM!! If this is an issue it should be addressed as NTSB message soon, cause a whole lot of 09 35d and X5ds will have this issue, my friend in Puerto Rico has an 09 35d and has had its share of problems with the SUPPOSEDLY EGR issue I gave him this link to take it to notice to AUTOGERMANA BMW of Puerto Rico to see if they have had same problem with other 35d or X5d
#31
Last time I was at the dealer I was told a recall was coming up, wonder if that had anything to do with any of this or unrelated completely.
--Aaron |
#32
Update: Cylinder head incoming from Germany, going to take another week at least. |
#33
will you update when it comes in?
Though I did not know the place, I set out for the land of my dreams. Having arrived at the land of my dreams, I found I did not know the place. |
#34
Sure, will do. It is coming from Germany so they don't expect it until Wed-Fri this week.
#35
This is really discouraging to hear and at such low milage. Clogged metering valves, carbon build-up requiring head replacement,,, oy vey....
![]() Why didn't they just clean it like the dealers can do with the 335i? I can't imagine it was that bad at such low mileage that it would require replacing the head. What's retail on parts and labor on this? |
#36
--Aaron |
#38
The big advantage we have is an entire continent worth of people who like diesel and many of whom drive diesels like ours and have with our very engine. I would imagine if there is a solution it will be from Europe first. Im sure someone knows about the EGR bypass or if it needs software. You can bet if I get this issue thats where I will look once warranty is up.
#39
e.g. http://www.e90post.com/forums/showth...arbon+build-up |
#40
Here in MD a well known DIY mechanic on e90post hosted a carbon cleaning event whereby his BMW tech friend brought out the walnut machine and the tech cleaned 4 or 5 cars for $400 a pop (about half what the dealer charges). Here's the thread, take a look at page 2 for some good pics.
http://www.e90post.com/forums/showthread.php?t=669314 |
#42
EDIT: Another thought, if the problem is just random things/ dust in the air sticking to the back of the valves then not having any thing to wash it off like it would in port injection, wouldent more frequent air filter change help?
Though I did not know the place, I set out for the land of my dreams. Having arrived at the land of my dreams, I found I did not know the place. Last edited by wanderlust; 04-10-2012 at 06:35 PM. |
#43
same thing happened to my X5d, after replacing the turbo and a couple other parts, I was told to avoid babying the engine too much, to ride it harder. Talking to a friend of mine who's a former diesel mechanic, it's very important to run the engine hard here and there, its vital to the life and health of the engine. The Bmw SA backed up that opinion. Now everyday I am driving I give it at least one real hard acceleration.
Current Rides: 2011 X5D Loaded (Oil Burner) 2012 VW Passat SEL TDI (Oil sipper) 2008 Honda CBR 1000 2007 Harley Davidson Sportster XL 1200 Retired: 2010 Mercedes GL350 (in the shop too much) 2009 335D ![]() 2008 Audi A6 3.2 Quattro loaded ![]() 2005 BMW M3 Black compertition Pkg with Nav |
#44
I don't know, I have heard SAs say that exact sort of thing for gas engines too. I often question where they gain this knowledge. But on diesels I have always noticed on the older ones if you are nice to them for a long time then have to get on it that the result is a much larger amount of soot. I always wondered if the is a fueling issue or a door build up the purging issue.
--Aaron |
#46
The EGR is put back in before the turbo right? Me thinks the turbo's should have been looked at as well ![]() I hate EGR too... that's why my truck no longer has it ![]() Once the X5 is out of warranty I hope they have DPF/DOC and EGR deletes for them as well. Unfortunately I'm sure the volume won't support it. Jay
Herbert - '12 X5 35d / Sapphire Black / Black Perf Nevada / Aluminum trim / ZPP / ZPS / ZCW / ZAV / Apps / 3rd row Betty - '04 CTS-V / Black Raven / Black Leather & Suede / 6 speed LS6 combo 400 hp & 400 tq Sterling - '06 Silverado HD / White / Grey Leather / LBZ Duramax - Allison 6 speed combo / Crew Cab Short Bed LT3 |
#47
I am not sure what you mean by the EGR being before the turbo. But also to be honest I am not sure how the specifics of the EGR system on our BMWs work. I know on my truck the way the layout is done caused for extreme gas temps and they have to use an EGR coolers. Now if those coolers are typical for all modern diesels is beyond my knowledge. I just really regret not doing an EGR bypass on my truck way back when my original cooler failed then I could avoide much later on the clogged up intake from a failed EGR.
--Aaron |
#48
Here is what Niel had to say about the egr bypass.... Hi Chris, I have a 525d Se touring 2002. It was easy to change and I did not get any lights on the dash nor from the scanner I used after 100miles. My egr valve was stuck open and no amount of cleaning world free it up. My car has 150000 motorway miles on it and the mod sharpened up performance and I get an improved MPG from 42mpg to nearly 50 mpg at motorway speeds.... Not an imperial gallon is more than a US gallon. If you follow the instructions it was easy to fit but lining the bolts up can be a challenge due to the tension of the pipe on the left hand side . Hope this helps PS I did not think the US embraced diesels? My pride and joy is a 1974 Jensen Interceptor with a Chrysler 440 V8 Big Block..... Uk price for fuel is close to $9 a gallon Neil Last edited by cssnms; 04-12-2012 at 07:54 AM. |
#50
Chris, great work (again) finding out info for us d owners! I really want to learn as much as possible about the EGR bypass, as this sounds like a mod that we really need to consider if we plan to keep the car past the warranty period.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
