E46 (1999 - 2006)
Old 04-09-2012, 04:35 PM
catso's Avatar
catso catso is offline
catso
Originally Posted by smolck View Post
Just one clamp, I use new ones as those snap on ones always seem to get "damaged" when I remove them.
This is a noteworthy update: The new fuel pump has made my car come alive again. I'll say that in my last E46 I had a dead pump and the car felt the same with the new one. But I must say, the one in this ZHP must have been "weak" since I got the car. But especially over the last 3 weeks. I would get 0171 and 0173 codes, the 4k rpm stutter had returned, and past 5000 rpm my car felt "weak". It just didn't pull after 5k rpm, it'd rev, but lamely.
Anyways ALL of those issues are GONE! My car pulls HARD all the way to redline, jumps right past 4k rpm with no stutter at all, and just feels way more peppy. I have nothing scientific to base this on, but I have a pretty big ass (some say it's on my shoulders) so my "butt dyno" takes a lot to register. The biggest things again are hard pulling from 5k-6800rpm and no more 4k rpm dip and those are EASILY felt.
So HAPPY! Too bad I changed my intake boots this weekend thinking they were the cause of my lean codes (they weren't cracked at all). But oh well, they are new now.
I also noticed an improvement in performance when I got a new pump. The clutch was prone to chattering when the car was cold, like there wasn't quite enough power and there was the feeling of uneven power in the lower ranges during shifts. After I got the new pump that went away.
![/I][/FONT]
Old 04-09-2012, 05:23 PM
MalibuMafiaV's Avatar
TheMalibuMafia
Mein Auto: E60 M5 & JB4+ 335i
Shad. How hard would you say the fuel pump is to DIY?. Is it harder or easier than say a diff swap?.
"Be yourself for who you are, or be no one at all" - MalibuMafiaV
TheMalibuMafia.com
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i. Single Turbo 6266.
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
Old 04-09-2012, 05:25 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
It's so easy it isn't even funny. Took me about 15 minutes. You remove the lower back seat, remove 4 10mm bolts that hold the cover on, unsnap the electrical connection, remove a clamp and a hose and then hammer the retainer ring out. It is a joke. So on a scale of 1-10 it is a 1.
Old 04-09-2012, 05:35 PM
TheMalibuMafia
hahahaha awesome! do I have to worry about spilling gasoline every where?. That might not be good. I feel like mine needs some help considering it has 181k miles on it. Wow I wonder if some of my problem is going to be fuel pump related.... never really thought about it since I got lean codes... would make sense since my AFRs were all horrible to especially if the car was starving for fuel. The car was idling oddly as well.
TheMalibuMafia.com
Old 04-09-2012, 05:57 PM
catso's Avatar
catso
The toughest part of the job was figuring out whether the seal ring should go on the tank or on the pump when reinstalling the assembly. If I recall, you have to put the seal ring on the tank to get it to seat properly.
![/I][/FONT]
Old 04-09-2012, 07:02 PM
JJ3699's Avatar
JJ3699 JJ3699 is offline
Send a message via AIM to JJ3699
Mein Auto: 2003 325i
Van, here is a DIY I found on YouTube... as soon as I read Smolck's first post I started looking for DIYs
.................BMW 4 LIFE.....................
Old 04-09-2012, 07:06 PM
catso's Avatar
catso
This is so easy that you can do it in less time than it takes to load and watch the video.
![/I][/FONT]
Old 04-10-2012, 12:21 AM
ACHOO330Ci ACHOO330Ci is offline
Mein Auto: 2004 330Ci
It's only easy if everything comes off as planned. When I installed the M3 fuel pump baffle into my 330ci, it took quite a bit of effort getting the lock-down ring to come loose even though I did it exactly as demonstrated in the video.
Old 04-10-2012, 04:31 AM
alfabmw1 alfabmw1 is offline
Mein Auto: 2001 325 xi
I have had two no-starts in the last 6 months, this may be the culprit. I just checked for pumps on-line, it looks like there are two, one on the left (drivers side), and one on the right (for 2001 325 XI). The video shows the one on the right being replaced, it is also the expensive one. I assume that is the one to go with?
Old 04-10-2012, 04:48 AM
gesoffen gesoffen is offline
Mein Auto: Rainbow Unicorn!
For all those who had to replace fuel pumps: What was your PM schedule on fuel filters?
----Brian
Old 04-10-2012, 06:11 AM
smolck's Avatar
ROLL TIDE!
The fuel pump is on the right had side (passenger). The left side pump isn't a fuel pump exactly, it is called a sucking jet pump. It sends fuel to the other side of the tank, rarely do they fail, but if you order a "fuel pump" it will be for the back passenger side.
I changed the fuel filter twice on the ZHP before I bought it for the PO. Once around 70k miles and again at 130k miles or so.
Old 04-10-2012, 06:57 AM
catso's Avatar
catso
The parts distributor I bought my fuel pump from also requires you to buy and install a new filter to get the full warranty. My old filter only had about 4000 miles on it so I put the new one in my spare parts collection.
![/I][/FONT]
Old 04-10-2012, 07:06 AM
Scottji's Avatar
Scottji Scottji is offline
Mein Auto: 2004 325i
Correct me if I am mistaken, but I thought the "sucking jet pump" was something different, submerged down at the bottom of the fuel tank, which, as you say, moves gas to the passenger side of the tank. I think the round pump-type thing under the rear drivers side seat is the level sender, which (I learned recently) should be replaced if your gas gauge is acting funny.
Old 04-10-2012, 07:10 AM
oembimmerparts oembimmerparts is offline
Mein Auto: 2001 Z3
E46 pumps are failing very often at the moment, To give you a idea we are at between 15-25 per week and it does not seem to be slowing down any.
Max
Old 04-10-2012, 07:27 AM
SeanC's Avatar
SeanC SeanC is offline
Mein Auto: E70 Xdrive48, F30 328i
Mine died on Friday at ~141k miles. New pump arriving today.
Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
Imola RedBlackBlack Aluminum e46 330i ZHP/6MT
Old 04-10-2012, 08:47 AM
Dibaltic Dibaltic is offline
Mein Auto: e46
my buddies fuel pump died on him just last week at i believe about 145k
Old 04-10-2012, 09:38 AM
TheMalibuMafia
Thanks man!. Definitely going to do this next pay check.
TheMalibuMafia.com
Old 04-10-2012, 10:01 AM
av98's Avatar
av98 av98 is offline
ZHP = Patlabor
Mein Auto: Mini Clubmn,Odyssey,Miata
Any idea of the brand and type of gas used contributes to the pump failure? Or if the tank has ever run dry which my cause the pump to overheat from an empty fuel tank?
Old 04-10-2012, 10:55 AM
Scottji's Avatar
Perhaps this is something that should be added to the Wiki? I didn't see anything in there on fuel pumps, other than a mention that replacing your fuel filter will help prolong the life of your pump. But with so much emphasis on a cooling system that will fail like clockwork every 90k miles and leave you stranded, might be a good idea to note the same thing for a fuel pump that will fail like clockwork every 140k miles and leave you stranded.
Old 04-10-2012, 11:14 AM
ckleung100 ckleung100 is offline
Mein Auto: '99 323i
I wish they had an access door to make the CVV so easy to replace too.
Old 04-10-2012, 11:37 AM
TheMalibuMafia
CVV isn't to hard to replace anyways:P just time consuming.
TheMalibuMafia.com
Old 04-10-2012, 11:55 AM
ECSTuning's Avatar
Instructor of the Stig™
Glad you got her fixed, VDO makes a great quality pump for a fraction of the cost of the genuine BMW pump.
I still can't believe the ONE TIME I leave my cell phone at home my car dies.
That's the way it always happens!
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172 | OEM BMW Part Number Search
Click HERE to read what people are saying about ECS Tuning
Old 04-10-2012, 12:01 PM
TheMalibuMafia
Wonder what I can fit in there that's not OEM spec. Like more of a beefy fuel pump for my SCed bimmer.... any thoughts?
TheMalibuMafia.com
Old 04-10-2012, 12:11 PM
ECSTuning's Avatar
Walbro pumps are rather popular with the boosted crowed.
Old 04-10-2012, 01:18 PM
TheMalibuMafia
That's what I was thinkin. Although I think I'll probably still just go with OEM to be safe.
TheMalibuMafia.com
