E46 (1999 - 2006)
Old 06-14-2012, 01:38 PM
cvx5832 cvx5832 is offline
Mein Auto: 325Ci, 325Cic, C300
I've seen these pumps fail more based on time than mileage. The pump went out on my 2003 325Ci with only 88k miles, driven mostly on freeways and on weekends, and that's with a fuel filter replacement at 50k.
I've always avoided including the pump as a maintenance item because I figured I always took care of it with scheduled filter replacements. I don't drive like a lunatic, either. But after mine started to make noise and failed, further research indicates they just conk out after a number of years submerged in fuel.
Old 11-13-2012, 10:33 AM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
Will a fuel pump throw a code at all after it fails?
I think mine on my 330i just died today at work. T
Old 11-13-2012, 11:41 AM
jdauria jdauria is offline
Mein Auto: E39 ///M5
I think it should but dont quote me on that. It'll be obvious if it fails, your car wont turn on no?
2000 ///M5 ///M Registry
Oxford Green Metallic II (430) | Caramel Nappa Leather (M3CR) | BMW Individual Black Birch |
Tuning Tech Tune by Frank Smith (http://www.tuningtechfs.com/)
Supersprint Headers
SuperSprint X-Pipe
Storm Motorwerks Products
2011 X5 35d | Alpine White | Beige | Sports Pkg | Premium Pkg | Cold Weather Pkg | 3rd Row
2003 X5 4.6iS | Black Sapphire Metallic | Black Sport | DINAN Software | FOR SALE!
Old 11-13-2012, 12:10 PM
Scottji's Avatar
Scottji Scottji is offline
Mein Auto: 2004 325i
Did you pull the rear seat and listen for it to wind up when you turn the key to "on" (but not "start")?
Old 11-13-2012, 12:35 PM
1972ford's Avatar
1972ford 1972ford is offline
Function over fashion
Mein Auto: 325xiT
Mine failed initially without warning. Drove it for 35 min, shut the car off and went to re-start 15 min later, all it would do is fire then die right away. It came to life after some encouragement and I drove it another 150 miles, though it did cause a misfire and poor run condition momentarily, which then tripped the CEL but this is 100+ miles after the first failure. Obviously not my first choice to keep driving it that way but I had no better option at the time.
If it had failed slowly it might have caused the CEL and misfire first, which could have actually thrown me on a wild goose chase. I'm kinda glad it failed the way it did.
oh and yes, what Scott said - if it's working you'll hear the hum for a few seconds under the rear seat when you first turn the key to 'on.'
Old 11-13-2012, 12:45 PM
mlukas161's Avatar
Thanks all. It definitely is the fuel pump.
I pulled the back seat up and there is no noise and no movement in the fuel pump. Also, I checked all fuses and swapped relays under the hood with my horn relay just to make sure it wasn't something electrical.
I hit the top of the fuel pump with a long wrench and sure enough it started right up.
I was able to get it home and in my garage.
Looks like I'll be ordering a new fuel pump today.
FWIW I have a 2003 330i with 88,000 miles.
Old 11-13-2012, 03:16 PM
MalibuMafiaV's Avatar
TheMalibuMafia
Mein Auto: E60 M5 & JB4+ 335i
I would like to state that I'm still on my original fuel pump at 184k miles. My next post might be "DIYing fuel pump".
"Be yourself for who you are, or be no one at all" - MalibuMafiaV
TheMalibuMafia.com
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i. Single Turbo 6266.
Audi S4 2000 Stage 3 - Dat turbo spool - SOLD
BMW 2000 3-series - Supercharged Because race car SOLD
Maserati 2004 M128 GT - HREs/tint/straight piped SOLD
BMW 2006 M3 - stock - SOLD
Old 11-14-2012, 05:31 AM
1972ford's Avatar
Mein Auto: 325xiT
haha, is that the last original mechanical part on that car?
The DIY is really easy: remove back seat, remove cover plate, disconnect wire harness, disconnect fuel hose, unscrew big retaining ring, remove pump & gasket, install new, screw down retaining ring, connect fuel line (recommend new hose clamp) and wire harness, replace cover plate, replace back seat. 10 minutes start to finish.
Old 11-14-2012, 08:29 AM
TheMalibuMafia
LOL. That and the power steering pump are the only original parts left. Yeah the DIY looks super easy. I drove the car yesterday night to go get some food. GOOD LORD every time I get in my bimmer it's a blast to drive and it's FAST as **** compared to the masi. Masi is fast after about 50 mph when it's rolling. But the bimmer.... that **** is so damn fast from 0-80 it's scarry. Plus the sounds it make, super charger whistle and the bypass valve air noise like a blow off valve
TheMalibuMafia.com
Old 11-14-2012, 10:18 AM
nivo nivo is offline
Mein Auto: 330Ci ZHP
The amazing thing is that this is a common thing on some BMWs, while other cars get scrapped with over 300k miles and not one issue.
The pump as tested by some manufacturers is by run time hours not miles. Also the higher the voltage to the pump and the higher the pressure the shorter the life. being that they run at 3.5bar...well this tells us something.
Old 11-14-2012, 10:56 AM
nekkibasara nekkibasara is offline
Mein Auto: 2001 325i
I wonder if the short lifespan of these plastic parts has anything to do with the excessively corrosive ethanol that is in all of our fuel now.
