E36 (1991 - 1999)
Old 04-08-2012, 05:03 PM
ccmueth ccmueth is offline
Mein Auto: 1997 328i
Removing Entire Ignition Assembly?
Hey guys, happy Easter. Can anyone point me in the right direction of removing the ignition lock assembly? To clarify, I don't want the barrel out, I'd like to remove the entire unit in order to get to the business end of the ignition switch. I have the lower cover off of the steering column, but I don't see an obvious method to going about this. Thanks.
K&N CAI, Dinan BBTB, Shrick intake manifold, Supersprint exhaust, Dinan Stage III software, Bilstein shocks, H&R springs, 3.23 LSD, Racing Dynamics strut tower bar, 17" M-Contours.
Old 04-08-2012, 05:54 PM
norcal_baller norcal_baller is offline
Mein Auto: 92 BMW 325is
are you wanting the ignition switch block out or tumbler and shaft?
Old 04-08-2012, 05:56 PM
If you wanting the block out, pull off the lower panel and on the left hand side you will see two small flat head screws. remove them to remove the switch block. the screws may have the heads painted head.
Old 04-08-2012, 05:58 PM
hornhospital's Avatar
D'oh, You Kids!
Don't be put off by the title of this DIY. The info you need is within this article:
http://www.pelicanparts.com/bmw/tech...t/E36-Tilt.htm
Quotes to live by:
Old 04-08-2012, 07:14 PM
Shigeta's Avatar
Shigeta Shigeta is offline
Old Soul
Mein Auto: '96 328is
This man speaks the truth. I've replaced this whole ignition assembly from this guide.
Kinda a PITA, but worth it.
barrel, ignition, lock, switch
