Looking to add HP on a budget - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > E90/E92/E93 M3 (2008 - 2014)
4th generation E90 M3 sedan, E92 M3 coupe and E93 M3 convertible. The last of the naturally aspirated M3s, powered by a 4.0 liter V8 making 414hp and 295 lb-ft of torque.
Old 04-08-2012, 06:53 PM
MarkyMark112 MarkyMark112 is offline
Mein Auto: BMW M3, E92
Hey guys, I recently purchased a 2008 m3 e92. The previous owner put on an afe intake and a few other exterior modifications but I am looking to add some more performance parts to the car. I am looking to get the most HP without spending anymore than $4-5 K. Any suggestions would be greatly appreciated. Thanks
Old 04-08-2012, 07:25 PM
PapaKlix PapaKlix is offline
Mein Auto: SG E92 M3
removing the primary cats via turner test pipes and a tune will get you some decent power gains for about $1500 (depending on who's tune you get). turner has dynoed this combination at +40hp vs stock. i would also replace the axle back exhaust with a light weight titanium exhaust, there's probably not much HP in that mod (some companies claim 10-15 hp); however, the stock exhaust is a pig. i couldn't believe how heavy it was when i pulled mine off. i think it weighs about 55lbs. my titanium exhaust weighs 19lbs. i have the vanguard titanium exhaust, you can get it from a board sponsor and great vendor modbargains.com for $2600: http://www.modbargains.com/Vanguard-...ust-System.htm
here's a comparison video i did so you can kind of hear the difference in sound:
after that, some people say pulleys will net you 10-15 hp for $400ish, i don't have any experience with them but am considering turner's and macht schnell.
i'm not sure that you can simply add up all the gains claimed by manufacturers and vendors to arrive at an expected gain for these items, but in my research i've found these are the items most people install for power gains in your budget. my "shopping list" above would total about $4500, right in the middle of your range
Old 04-09-2012, 05:58 AM
Wow, the exhaust makes all the difference in the world, great video. Thanks for the recommendations, those are substantial gains for limited funds.
Old 04-09-2012, 04:25 PM
650 Ryder's Avatar
650 Ryder 650 Ryder is offline
Mein Auto: Dinan///M3 - Countryman S
I would agree with the above......biggest bang by far is to go catless. This was the biggest difference in HP for me. As you can see in my signature I have a couple mods . My set up works well as a package......if you only want to do one or two......loose the cats and get a tune...............Phil
2011.5 Dinan ///M3:
SSII DCT
Comp, Conv, Prem 2 Pkg
Heated Seats
Enhnd Prem Sound
BMW Edition Grills / Gills
BMW M Perf. Steering Wheel
BMW C/F Perf. Spoiler
BMW Pedals
Dinan Exhaust
Dinan Mid Racing Exhaust
Dinan Carbon Fiber Intake
Dinan Racing Middle Exhaust Software
Dinan DCT Tune
Dinan Pulley Kit
Dinan CH-R Wheels
Dinan Carbon Fiber Strut Tower Braces
IND M5 Scheme Mirror Caps
Arkym Front Lip
C/F Reflectors
Lux H8 V3
Brembo 365mm BBK
Swift Spec-R Springs
Old 04-10-2012, 12:13 PM
That does appear to be the best way to get big gains however I would still like to pass emmisions testing. Wouldnt removing the cats cause the car to fail emissions? Maryland is pretty stringent about emissions, is there a way around it??
Old 04-10-2012, 12:53 PM
i don't know maryland's emissions testing process but given the political climate there, i'm pretty sure you won't pass emissions after you remove the primary cats. your option would be to either keep your x-pipe intact so you can install it for emissions testing or get a hi-flow cat x-pipe that would pass emissions. the former is probably technically illegally so i wouldn't officially endorse it but the latter is more expensive and will generate less in terms of HP gains.
Old 04-19-2012, 11:57 AM
ModBargains III ModBargains III is offline
Mein Auto: E92, E82, E46, E39
If you want big gains, I'm the performance guy over here you can talk to. I'll send you a PM, maybe we can get some kind of packaged deal worked out for you
Sean Singh | Modification Expert | Sean@modbargains.com | (714) 582-3330 ext. 8009
BMW Wheels | BMW Brakes | BMW Suspension | BMW M3 Parts | KW Coilovers |
AE Performance | Remus Exhaust | BMW Performance Exhaust
Hours: Mon - Fri 8:00am-6:00pm | Sat 8:00am-5:00pm (PST)
Check out the Blog!
Old 03-02-2016, 02:36 PM
JLIT JLIT is offline
415-Series
Send a message via AIM to JLIT
Mein Auto: 2002 BMW 530i (E39)
May have to have you work with me on my 08 335i. Have a jb4 with DCI already but wanted to add exhaust (not looking to get the race exhaust type notes but definitely want to achieve that gurgle and audible roar if desired. I'm in LAand would love to bring my car down there to look at some of my options. Downpipe a possibly also depending upon the exhaust choice and cost of course. Would this be do able? Sorry to hijack post in advance
Old 03-03-2016, 02:33 PM
Db750's Avatar
Db750 Db750 is offline
David
Mein Auto: M3 - M6 - 911
Considering the thread you are replying to is four years old this would be considered a "resurrection" not a "hijack".
2014 Carrera 2S - White/2 Tone Espresso/Cognac - Aerokit - PSE - PDCC - SPASM - PDK - Sport Chrono - 20" wheels w/OEM Spacers - Glass Roof - Leather Dash - way too much more to list
2013 F12 M6 - Alpine White/Black Merino - Executive - LEDs - B&O - DA - Lots more
2013 E92 M3 - LeMans Blue/Black Novillo -(Lease ended need new signature pic)
Old 04-06-2016, 07:51 PM
jzyaa jzyaa is offline
Mein Auto: M3 E93
for 4k-5k budget, you probably coudlnt do supercharger.
i'll suggest you take out catalyst converter, put on Turner Motorsport's test pipe, with their racing ECU, easy to install. those 2 things come with a bundle, cost $1300. it gives you about 48hp and 32ft-lb gain.
seconds thing is exhaust. try to get aFe exhaust since you already have afe intake. works well. you gain 12hp with the afe cat back itself, cost about $1400-1500 only.
and try to get a power pulley, it gives you another 12hp with only 300-400 cost.
with those modifications you spend only about $3200, but you gain about 68-74 hp.
if you want F1 sound, get ipe exhuast for about $6300.
you don't need to change X pipe because all x pipes would be the same.
Old 06-04-2016, 08:51 PM
Shayne S Shayne S is offline
Mein Auto: 2011 M3
If you put a tune via a piggy back chip it will pass emissions. My does.
