Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > E36 M3 (1995-1999)
E36 M3 (1995-1999)
Old 04-12-2012, 03:23 PM
SwimNDrive SwimNDrive is offline
Mein Auto: 1997 BMW M3 Coupe
E36 M3 What is this in the spring?
Hi everyone,
I purchased a 1997 M3 few months ago. It runs well to me so far. But since I am new to M3, there is a lot for me to learn about this car. One thing I noticed last time I took off one of the rear tires, there is an metal object inserted into the spring coil. Then I found the same kind of object in the spring coil on the other side as well. It looks like they were put in the springs with a purpose. Can anyone tell me why these objects were in the spring coils and should I keep them there?
Any help is greatly appreciated. Thanks
Old 04-13-2012, 06:31 AM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is offline
Aficionado
Mein Auto: '05 X3, '95 M3, '89 MkI
No idea what it is or why someone would put it there. It could be compromising handling integrity, I'd take them off there...
"If everything seems under control, you're just not going fast enough"
-Mario Andretti.
___________________
River City Bimmers Chapter
2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta.
1995 ///M3 Coupe, Lux, MT, Htd seats, Cosmos Black on Black.
Old 04-13-2012, 09:59 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
They probably affect the springs compression properties. I'd take them out. It doesn't look safe.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by EnserioJose View Post
Sorry. I'd imagine Seattle is a-hella-nother country.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
Old 04-13-2012, 10:08 AM
ECSTuning's Avatar
Mein Auto: e30
Looks like someone was trying to raise the car slightly by putting those blocks in between the coils. I would remove them.
800.924.5172
OEM BMW Part Number Search
Old 04-13-2012, 03:11 PM
This car has been lowered. The wheels are 18" aftermarket wheels. I have concern if I take them out, it may cause some problem. I got advice from the other forum that I should check out the spring first and see what they are then make next move. This is not my daily drive. In the meantime, I need to take care of the CV boot. Over the weekend I will raise it up and check out the spring then see what will be the next. Thanks a lot, everyone for the response.
Old 04-13-2012, 03:47 PM
fun2drive's Avatar
BMWCCA 149159
Mein Auto: 335 vert//M3/4/ 13Outback
What you are seeing is called a spring spacer and you almost never see them anymore...
Designed to help weak springs that need lift...
Old 04-13-2012, 08:27 PM
Does it mean I have the weak springs? Instead of having these things in my springs, should I consider replace the springs at this time? What are my options? Thanks
