E36 (1991 - 1999)
Old 04-13-2012, 09:19 AM
ccmueth ccmueth is offline
Mein Auto: 1997 328i
EWS Woes
Hey everyone, happy Friday. Does anyone have any information regarding permanently disabling the EWSII system? I'd like to completely bypass my broken ignition lock cylinder with a push-to-start system rather than paying for another one to be cut. The only problem is the EWS, as I'd like to not have to have any type of key in the ignition for the system to function.
K&N CAI, Dinan BBTB, Shrick intake manifold, Supersprint exhaust, Dinan Stage III software, Bilstein shocks, H&R springs, 3.23 LSD, Racing Dynamics strut tower bar, 17" M-Contours.
Old 04-13-2012, 10:12 AM
Shigeta's Avatar
Shigeta Shigeta is online now
Old Soul
Mein Auto: '96 328is
I was in a situation similar to you a while ago. I researched it and I concluded that it is WAY easier to find a used EWS/Key/DME ECU combination off eBay or off a parted out OBDII EWSII car than try and delete the EWSII system.
I remember a while back I bought my combo stuff for $150 or so off eBay, took an hour or two to install and I was done! Cheaper than dealer prices, easier than dealing with EWSII
Old 04-13-2012, 10:26 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
So you want to be able to start your car with no key in the ignition? How would you turn on the car's systems? What would prevent people from stealing your car?
1998 BMW 328is
1966 Pontiac GTO
Old 04-13-2012, 03:50 PM
Thanks for the info, I'll look into that as an alternative.
Old 04-13-2012, 03:58 PM
I should have been more clear on this. I'd like to still have a key/remote to unlock and lock the doors and glovebox, but not have to physically have one in the ignition in order to start the car. The turning on of the systems would be accomplished by switches in addition to the actual push-to-start button. As a theft deterrent, I would obviously keep the doors locked at all times that I am not in the car, and have an alarm system as well.
Old 04-13-2012, 04:18 PM
Shigeta's Avatar
Old Soul
This is a similar system I had going for a long time. I'd advise against it as it is very easy to break into the car and disable the alarm pretty easily.
If you do that, however, I'd recommend adding a fuel pump kill switch at the least. Think of wherever it'd be smart to put a kill switch and don't put it there
edit: Now that I think about it, to "disable" my EWSII system, I just taped the key next to the antenna ring and hid it inside the dash...
Old 04-14-2012, 09:08 PM
Thanks, a kill switch is a good idea. And that's a great way to get around the EWS. I appreciate the info.
Old 04-14-2012, 09:12 PM
Gooby's Avatar
Gooby Gooby is online now
Kebab Lord / Sexy Sax Man
Mein Auto: 1995 M3
ews2 cannot be bypassed, only reprogrammed.
Old 04-14-2012, 09:34 PM
norcal_baller norcal_baller is offline
Mein Auto: 92 BMW 325is
i dont know if the make it or not, as i havent looked into doing this. but some newer cars with the push start button have to have the key in the car for it to work. something with the chip in the key or sensor. i wouldnt recommend this even with alarm/lojack or fuel killswitch. this is just setting yourself up for failure. problems such as bad wire hook-up. ie catch car on fire, or just easier to steal or even hotwire for that matter. you can elimate the steering wheel lock easily with no hard mods. but i would stay clear of PTS.
:3, ews, ignition, lock, push start
