steering wheel turn makes rub noise/feel - Bimmerfest - BMW Forums
Old 04-13-2012, 06:07 PM
rh71 rh71 is offline
Among the Proud
Mein Auto: X5 3.0si
I can feel it in the steering wheel (very slight vibe) and hear a rubbing sound when I make slow speed turns, while the wheel turns. For example turning into my driveway. It's not a squeak. I don't have active steering. Is this a belt issue? Something need grease? I guess I gotta check my PS fluid too.. but I can't find a reference in the manual.
'08 3.0si with 28k miles
'08 X5 3.0si - Alpine White / Saddle Brown interior
Specs: Sport Pkg, Premium Pkg, Tech Pkg, Comfort Access, Aero Kit, Style 433 staggered 20s on Conti DWS
Mods: Carbon 35 tint, LED angel eyes, GP Thunder 7500k fogs, H&R 20mm/25mm spacers, clear reflectors, gunsmoke-tinted taillights
Coded: Digital speedo, windows/sunroof/tailgate close via keyfob
X5 pics at Flickr
Old 04-15-2012, 10:07 AM
RPsX5d RPsX5d is offline
Mein Auto: X5 Diesel xDrive35d
I believe I have the same exact issue . . . but I felt it came from inside the passenger cabin - meaning the rubbing sound was some plastic piece rubbing against another surface. The only thing I can say for sure is it happens at parking speeds, steering wheel is turned nearly all the way to one side (yes it has happened on both left and right turns). I was planning to get this addressed at my next routine maintenance visit.
The BMW logo on the steering wheel had some marks on it . . . didn't see it when I took delivery, got the dealer to change it after about a year (warranty covered it). As I understood it, Dealer changed the entire air bag assembly . . . not sure if this has anything to do with this "rubbing sound".
Anyone else with this issue? Did you get this fixed?
Old 04-16-2012, 06:25 AM
Among the Proud
Mein Auto: X5 3.0si
I did have low PS fluid (checked when car was cold) so I filled it but the sound does still occur but less frequently. I was wondering if this could potentially cause some kind of worse failure down the road if left unchecked. Not as easy for me to bring it in since I have to go to an indy (no shuttle/loaner) so minor annoyances can wait. If it is just a minor annoyance that won't cause bigger issues...
X5 pics at Flickr
Old 04-16-2012, 02:04 PM
sevenseries sevenseries is offline
Mein Auto: 2003 BMW 745i
I have a similar rubbing sound, but not when I'm turning. When I first power on the car and the steering wheel tilt adjusts to my preset, there is a squeaking/ rubbing noise. It's much louder and more pronounced in hot weather. Has anybody else experienced this?
Sent from my DROIDX using Bimmer App
Old 04-17-2012, 07:21 AM
Yes mine is also intermittent - seems to occur when the weather is dry and hot.
Hate intermittent problems, hard to tell if the dealer actually fixed it. Hopefully by the next service visit this issue will become more consistent and easily repeated.
Old 04-17-2012, 02:39 PM
eschnabs eschnabs is offline
Mein Auto: 2003 530i
Just had a similar issue fixed on my wife's 2010 X5 Xdrive30i...with 24,000 miles on it. Here is what the repair sheet said.
"Customer states steering wheel is noisy when you turn the wheel." Test drove and duplicated noise at lower steering column. Survey faults with ISTA and work test plan for steering noise. Per test, removed lower dash panel and inspect. Located noise at steering shaft collar bushing. Per test, lubricated bushing and retest. Correct noise complaint.
We have had the vehicle back for a few days now and so far so good. Hope that helps.
Old 05-20-2012, 06:06 AM
georgejm georgejm is offline
Mein Auto: BMW X5 35d
I have it now. Start it up and just a little tension left or right I can hear and feel a rubbing and it goes away after I pull off. What? I really do enjoy my X5 so far.
2012 X5 35d AW/Black Dark Burl
ZAP ZAV ZCW ZPP ZPS ZRC ZTP HUD AD BMW Apps
Spare Tire-Comfort Access-Running Boards-Roof Rails-335 Wheels-Auto High Beams-Smart Phone Int.
Mods : Clear Bra-Radar Hard-wired
So far so good-made on Wednesday
Old 05-20-2012, 06:34 AM
chip4's Avatar
chip4 chip4 is offline
Mein Auto: 2011 X5 35d
Ive had this for a while now -intermittent squeak/ noise in steering wheel. slow speed turns, dealer cannot duplicate.
Other items the dealer cannot duplicate:
Intermittent R Rear passenger door unlock delay
Brake squeal
Old 05-20-2012, 06:43 AM
Did you check PS fluid?
Old 05-20-2012, 08:31 AM
chip4's Avatar
Yes, noise is coming from the steering wheel column area. In the past they replaced my steering wheel because leather stitching was unraveling.
Old 05-20-2012, 10:06 AM
Brake squeal
+1
Exactly my issue . . . I just can't duplicate it at the Dealer! Waiting for it to get worse and then address it.
Regarding door unlock - the car goes into a sleep mode 30 minutes (I think) after engine shut off/door lock. Prior to unlock it has to wake up - usually this happens when it detects movement (at least that is what is happening inside my garage where I can observe/hear better). If the car is awake, doors unlock readily - I found this behavior most obvious when unlocking the tailgate - sometimes I have to click the tailgate unlock button (above license plate) a couple of times for it to open.
One simple check - next time when the delay happens write down if the car was left locked for at least 30-45 minutes. If this is consistent, the delay is just the car waking up.
Not sure why only the rear doors are exhibiting this behavior - unless this just happens to be a coincidence.
Brake squeal - try giving it a thorough wash using some good wheel cleaner . . . I was able to get rid of mine by washing it thoroughly. These cars have an electric brake pad wear sensor . . . not the old style mechanical one that squeals to let you know the pads are worn out.
This is exactly what I think is happening in my case . . . my problem - it is not happening consistently . . .
Old 05-28-2012, 01:09 PM
robeh1 robeh1 is offline
Mein Auto: BMW 325I COUPE
Question
Yep my E92 has a rubbing noise from whats sounds like behind the steering wheel not there all the time buy annoys the hell out of me, mine a 2007 with the fully comp BMW insured warranty, wonder what the chance of having this done for free???????????????
Old 05-29-2012, 05:09 AM
Marshotel Marshotel is offline
Mein Auto: 2017 X3xdrive28i on order
I had the exact same issue on my 2010. They initially thought it was in the column but their "fix" only had me back a short time later. They wound up replacing the rack and that resolved the issue.
I'll keep my guns, freedom and money.......You can keep the "change"
Old 05-12-2015, 10:32 AM
BMWLedwaba BMWLedwaba is offline
Mein Auto: BMW 320i E90
Hi Guys my Car(E90 320i) has a rubbing sound on the power steering when I turn the steering wheel this happens always in morning when the car is still cold, after driving to work I can hardly hear the sound.
Please help.
Old 05-14-2015, 09:55 AM
Among the Proud
Mein Auto: X5 3.0si
just to report back, 3 years later, it just went away on its own. Had completely forgotten about this so it's been a while.
X5 pics at Flickr
Old 05-14-2015, 10:44 AM
okay but can you assit me with my problem post above please.
Old 03-09-2016, 12:54 PM
FOe92 FOe92 is offline
Mein Auto: 2012 e92 xDrive
Mind if I ask if this is similar to what yours sounded like?
Old 05-10-2016, 01:12 PM
HI Guys I am having a problem with my BMW 320i E90 is has a coolant leak somewhere but I can't locate where, everyday I have to refill the coolant as it gives me warning that coolant is low, I have tried to look on the radiator hoses but could not find anything are there any Hidden hoses that I can search for? since I don't see any trace of leakage where could the coolant be disappearing to? Please help
Old 08-22-2016, 08:35 AM
Nickstocks99 Nickstocks99 is offline
Mein Auto: Bmw 325i
My 325i steering wheel is making this noise. What is it?
