Old 04-16-2012, 11:28 AM
1996bmw740il 1996bmw740il is offline
Mein Auto: 1996 740il
creaking suspension noise
I have a 1996 740 I l that my front end seems to be creaking at slow speeds when I turn the wheel or go over a small bump. Any ideas
Old 04-23-2012, 01:15 AM
Andy760 Andy760 is offline
Mein Auto: BMW 760, BMW 740
This is probably a ball joint. Jack up the wheel and check for movement. Sometimes they creak before you can feel movement so yoy may need to check it again.
Old 04-23-2012, 05:30 AM
chrisn7 chrisn7 is offline
Mein Auto: 750iL
If it gets worse when the car is warm, suspect the centre tie rod. The ball joints dry out with all that heat, leading to the creaking
Old 05-14-2013, 06:54 PM
cobiaboats cobiaboats is offline
Mein Auto: 2001 740il
What is the cure for ball joint creak? is it a lube or a replacement on a 2001 740il?
Old 05-26-2013, 01:35 PM
Otis DeBoard Otis DeBoard is offline
Mein Auto: 2001 740IL
It's probably time to change the control arm bushings or easier change all the control arms. The front has 2 per side then the stabilizer links. You can get a kit for the front and back for about 700$
Old 05-26-2013, 06:03 PM
ebida3's Avatar
ebida3 ebida3 is offline
Society of the 7's East
Mein Auto: 2001 740iL
Lower control arm bushings Very typical. These cars tend to be very front heavy so those control arms take a beating.
Old 07-19-2013, 02:56 PM
V8vinny V8vinny is offline
Mein Auto: E38 740i
It's the entire steering track rod ends and the centre control link I changed mine after hearing the noises you described and now it's quieter than a dead badger
HTML code is Off
