Old 04-17-2012, 07:35 AM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
Gary's updated CCV thread
OK, it's not Gary who's starting this thread, but I hope he jumps in and start giving us some feedback of some sort.
Gary buddy, you said you will start this thread very soon. So I started it for you. Now spill the beans.......
I know I have to refresh my CCV this summer, and I need to know where I'm sitting. Don't want to buy another winter version, only for you to come with the news 2 days later that Gary's new CCV is out.
Looking for a DIY? Parts? Check this out, it might be your ticket
TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint
Stable: e39 M54, e53 N62 & Tribby
Old 04-21-2012, 11:09 PM
gary@germanautosolutions's Avatar
gary@germanautosolutions gary@germanautosolutions is offline
Mein Auto: 528-530 Hybrid, Duc. 748
doru,
You crack me up, I laughed for five minute after I saw this.
I've been trying to get a few minutes to respond to this ever since you made the post, but my week has been horrible. I do have some updates regarding the testing we have done with applying full manifold vacuum to the crankcase without the pressure regulation of the CCV valve. I will try really hard to post something tomorrow. I just wanted you to know that I was not intentionally ignoring this.
Gary
"I'm a little rascal on my Little Rascal"
- unknown
Old 04-22-2012, 09:24 AM
doru's Avatar
OK, waiting on updates then. Can't hardly wait.
Old 06-08-2012, 12:06 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Don't forget the dipstick guide tube retrofit when you re-engineer the CCV system ...
- How can we clean out a clogged oil dipstick tube (connection to CCV)?
And, CCV testing procedures:
- How to test the BMW E39 pressure-controlled crankcase ventilation system (CCV)?
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
Old 06-08-2012, 10:57 AM
The kit is going to include a new redesigned dipstick tube.
Gary
- unknown
Old 06-08-2012, 11:38 AM
doru's Avatar
I have the re-designed dipstick tube. Will this be the same as yours?
Old 06-08-2012, 12:21 PM
The current design incorporates the updated OEM dipstick with additions. If volume allows, we will make our own entirely in house.
Gary
- unknown
Old 06-08-2012, 12:27 PM
doru's Avatar
Thanks.
How long do you think until the redesigned kit is commercial?
P.S. : i think I will be among the first ones to snag it......
Old 06-08-2012, 02:32 PM
Tuskfish Tuskfish is offline
Mein Auto: 2001 530i
Originally Posted by doru View Post
Thanks.
I'll be right behind you doru!
Old 06-08-2012, 02:59 PM
bluebee's Avatar
Personally, I think it's better to reward Gary's team with our orders for the redesigned dipstick tube guide sans the concentric rings than to give BMW even more money - which, in effect, rewards BMW for their faulty design.
Old 06-08-2012, 03:16 PM
Jason5driver's Avatar
Jason5driver Jason5driver is offline
Mein Auto: E39 hamster w/ pin-wheel
thanks.
P.s. : I think i will be among the first ones to snag it......
Old 06-12-2012, 01:49 PM
I am almost positive that my CCV is again done for....
I had a retired BMW master tech. (after 28 years) read the live codes on my car last weekend.
He said the catalytic number was 14, and should read 0, and some other number (I can't remember what...) reads 4, and should read somewhere around 14...
Hence, the reason for my hesitant acceleration when hitting the gas...
He said the timing was retarding...
And, he said the car's high crankcase pressure is the reason for my car's failed oil-pan gasket, and why my fuel pump is making noises (suspected failing again - pump was replaced just last year).
He first suggested replacing the Purge Vent Valve, then later, said to spray a whole can of B-12 carb/throttle body cleaner through the throttle body while the car is running...
This sounded kind of "old-school" to me...
Thoughts....?
I am so tired of changing/replacing this damn CCV...
Jason
Old 06-12-2012, 01:51 PM
doru's Avatar
What is the purge vent valve?
Old 06-12-2012, 01:54 PM
I think it is this:
http://realoem.com/bmw/showparts.do?...98&hg=13&fg=15
01 FUEL TANK BREATHER VALVE
PN = 139 01 433 603
$82.88
Old 06-12-2012, 04:39 PM
doru's Avatar
Ahhh!!!
OK, thanks Jason. Weird how that pesky CCV can cause so much trouble.
Why is it that the M54 engine has more oil pan gasket failure than the M52? Is the CCV designed different? (If the oil pan gasket failure is due in part by failed CCV)
Old 06-12-2012, 09:42 PM
Ahhh!!!
Yes, I think it is ALL related...!
Notice, the only oil pan gasket repairs you read about are on M54's...
Coincidence...?
I don't think so...
Plus, I think the bad CCV is causing Oxidation and Nitration within the oil (varnishing-up and becoming acidic)...!
Very BAD...!
I found this great article about Oxidation in Oil:
http://www.midtownoil.com/downloads/...ting%20Oil.pdf
Pretty interesting…......
"While controlling temperature and using higher-quality base oils can help limit the
degree and rate of oxidation, the eventual breakdown of the base oil molecules due
to oxidative processes is inevitable."
I also found another great article:
http://www.bobistheoilguy.com/whatisoilanalysis.htm
"Oxidation measures gums, varnishes and oxidation products.
High oxidation from oil used too hot or too long can leave sludge and varnish deposits and thicken the oil."
Nitration:
http://www.bobistheoilguy.com/forums...t&Number=16187
Nitration results from the heating of O, O2, N2, OH, and H in the
cylinder during combustion. The separate gasses mix
and when burned, form many resulting gasses
including NOx.
NOx generation is highest during: high
pressures, high temperatures, during crank angles between 10 and 40
degrees, and when the A/F ratio gets near
16:1, such as in lean-burn engines.
NOx gets into the oil via the blow-by gasses
during the power cycle when the cylinder pressure is highest and when
when the temp of the burning gasses is highest.
EGR valves and large overlap cams introduce
exhaust gas back into the cylinder to cool it down, reducing generation
of
NOx.
NOx creates peroxides that attack the oil and
increase oxidation as well.
Old 09-26-2012, 07:50 AM
doru's Avatar
Originally Posted by gary@germanautosolutions View Post
Stuff deleted
Now for updates on other products:
CCV - Minimal progress, but I do now have a rapid prototype for checking fitment and tweaking dimensions. I will be back on this heavy in about 2 weeks and hope to have a sellable product by the end of the year.
Stuff deleted
Thanks for your patience,
Gary
So there is hope.........
Old 02-24-2013, 12:42 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Send a message via MSN to bmw_n00b13
Mein Auto: 99 528iA
It seems to me that the core of the redesign is the CCV, which is mostly common between the M52TU and the M54 engines, and it's a problem on both. Hopefully this means the 528 owners get one too! I'm good to beta test!
'99 528i ('98/12 build). 174,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals
'99 540i (grandfather's)
Old 02-24-2013, 08:29 PM
Contrary to how it may appear, there has been some progress on this. I want to assure everyone that there has not been any issues with the initial design concept, just time on my part to make significant progress.
I am waiting for a second version of FMD rapid prototypes to come back so we can continue fitment testing. The problem is the tight clearance around the oil filter housing, intake VANOS solenoid and valve cover venting port. We are trying out a longer version with a different type of cap nut. Once we can verify a good fitment position that allows easy access for servicing I will get started on actual metal prototype parts.
I think most of you have noticed that there is an automated email link on the website that allows you to sign up for CCV updates and get first dibs on the first production units. There have been so many responses to that link that it is helping me try to find more time to fit this into my development schedule.
On another note:
For those who are not aware of it, we have released our 1.2bar coolant caps and will be releasing our M62-tu version of cam tools early next week. We spent a huge amount of research and development time on both of these products and we are very proud of the results.
The coolant cap should drastically reduce cooling system explosions and the M62 cam tools are a big inprovement over the factory tools in accuracy, ease of use, and most of all, affordability.
http://www.germanautosolutions.com/b...12_bar_cap.php
Thanks everyone for your support, patronage and patience,
Gary
- unknown
Old 02-24-2013, 08:47 PM
Albo's Avatar
Albo Albo is offline
Der ursprünglich....Albo
Mein Auto: OO=[][]=OO
Am I still getting the first one, Gary? :-)
Want to learn about your E39 5 Series?
Click Me
2003 530iA - Mumbo Jumbo *E39 in Sig is Not My Car
Originally Posted by edjack View Post
If you don't want to do nothing, you must want to do something.
Old 02-24-2013, 08:51 PM
Yep
- unknown
Old 02-24-2013, 09:15 PM
Albo's Avatar
Woohoo! My car really needs a new CCV!
Click Me
Old 02-24-2013, 10:56 PM
bluebee's Avatar
Originally Posted by Jason5driver View Post
I thought the purge valve was for gasoline, not oil?
- BMW_TIS_11.09.20_3_SI_E38_E39_New_Evaporative_Char coal_Canister_Purge_Line.pdf (62.1 KB, 194 views)
Maybe I misunderstood 'which' purge valve - but if it's this one - it's for gasoline:
- How to replace the LDP leak detection pump charcoal canister (1) (2) & does spilled gasoline go into the charcoal canister (1)
