Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series
6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations.
Old 04-18-2012, 04:29 AM
jacobsweden jacobsweden is offline
Mein Auto: 645Ci -2004
Remove plastic trim front of sunroof?
I have a rattle noise coming from the sunroof whenever I drive over bumps and stuff. I have located it and it seems like it's coming from the front of the sunroof. There's a plastic trim in the front that I'm trying to remove but I can't figure out how it's fitted and I don't want to break it. I'm guessing there's a screw of something loose behind that plastic piece which causes the noise.
Does anyone know how to remove this plastic trim?
'09 740i (Black sapphire metallic)
Old 04-18-2012, 06:18 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Here are all the TIS sunroof related instructions.
Is this the piece you are talking about?
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 04-19-2012, 12:30 AM
Originally Posted by Yorgi View Post
Hehe that's correct! I had a look at spaghetticoder but I must have been blind because I didn't find that TIS. Thank you!
Old 04-19-2012, 09:49 AM
Yorgi's Avatar
For some pages you need to make sure the proper model is selected. I normally browse the spaghetticoder site with an E64 cab as my model. In this case (e64) the sunroof links are all greyed-out. You must select E63 to see sunroof links.
'04 M3 - track
Old 12-22-2012, 01:15 PM
WDKIK WDKIK is offline
Wilma
Mein Auto: Z3 3.0i Roadster
Hi Yorgi...I have he same iisues as jacobsweden...however the links you provided don't seem to work for me when I click on them...Can you please repost the links...My moonroof when closed will rattle...If I apply gentle pressure along the aft section when closed, the roof will open up about 5mm...Thanks
Old 12-22-2012, 02:24 PM
Yorgi's Avatar
Unfortunately the site that we have been using for years, spaghetticoder.net, no longer has the BMW TIS manual online.
I do not know of another online copy of the TIS. If I get a chance I will try to upload the pages from my local copy of the manual.
'04 M3 - track
Old 12-23-2012, 11:05 AM
Wilma
Thanks anyway...I decided to take off the interior cassette rubber guards and found all 4 of the torx screws loose...So, I closed the moonroof back down and tightened in situation...Rattling has stopped and there is no wind noise...
