E34 (1989 - 1995)
Old 04-20-2012, 10:52 AM
rdc rdc is offline
Russell
Mein Auto: 1995 525iA
Originally Posted by CarDriver View Post
So true, a guessing game
Personally, I try to stay away from quick fixes like that if I can avoid it. But I have used rat-poop pellets in many a cooling system until I had been able to replace what was wrong
The only time I would tell some one specifically to stay away from a given product is if it had a proven track record of failure or I had a bad experience with it. IE, Steel-Seal... Stay far away LOL...
Only reason i am trying it as I felt, from what I read, there will be no harm from the product even if it does not help. Just did it for giggles unless it works!
1995 525i auto, 1/95 build, EAT chip, abt 239K miles, , HID, Lumbar, Oxford Green/Parchment, rebuilt trany @ 211K
Old 04-20-2012, 11:05 AM
CarDriver's Avatar
CarDriver CarDriver is offline
Mein Auto: 1992 525it /2004 ML350
Nothing wrong with that. And if it does work, that is wonderful thing.
Old 04-20-2012, 11:48 AM
1995i540's Avatar
1995i540 1995i540 is offline
Founder @ Maintenr
Mein Auto: 1995 540I/6
Those rat poop ****s make such a mess in cooling system
///////////////////////////////////////////// E34 Addicts
Founder @ Maintenr. Take control of your vehicle maintenance.
Old 04-22-2012, 03:19 PM
rdc rdc is offline
Russell
I checked the oil drips for the past 3 days over paper towels. They are getting smaller every day. However I have only driven about 115 miles and about 90 minutes drive time. No impact on engine sounds or drivability
Old 05-04-2012, 07:46 AM
rdc rdc is offline
Russell
Oil leak/drips have almost stopped. just a small amount and seems to be smaller each day. However I have only driven about 300 miles. 5/4/2012
Old 05-04-2012, 09:31 AM
ross1's Avatar
ross1 ross1 is offline
Mein Auto: Pretty much had 'em all
The oil filter housing has a paper gasket so no rubber for that stuff to swell which is the usual method for this type product. Personally, I'd be afraid of this stuff softening all the other expensive to replace seals to the point of failure.
How is the new, new trans holding up?
EDIT: Ooops, I stand corrected, I see you have an M50 engine(I live in an M30 world)which has a rubber seal.
Do you plan to leave the stuff in if and when the leak is corrected?
While I am no fan of fixes in a can the comparisons to fix-a-flat and cooling system fixes are not valid. Good luck with this.
Take my advice, I'm not using it.
Old 05-04-2012, 09:38 AM
rdc rdc is offline
Russell
Really, that I did not know. it looked like a rubber gasket in photos I have seen thats one reason i used White Shepherd. I will look for a better picture. Thanks.
There is a trany problem. When cold (below abt 35 degrees) , it will momentarly slip out of reverse on first start of the day. otherwise perfect. The rebuilder and indy shop are going to replace the trany under warrenty. it is on order from the rebuilder.
Old 05-04-2012, 09:42 AM
ross1's Avatar
See my edit. My M30centric head at work
Good luck on the trans too.
Old 05-14-2012, 10:59 AM
rdc rdc is offline
Russell
I have driven over 700 miles with White Shepherd in my crankcase. Looks like leakage is about 1/2 of what I had. It did help.
I now have about 2-4 small drops clustered in about a 6 inch circular area if the car is let set overnight Each drop is about 3/4 to 1 inch in diameter on paper towels I spread under the car. IMO, the leak is not reduced enough. I will need to fix it.
Old 05-14-2012, 02:13 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
I like the idea behind the product. If the drips dont positivily smell like motor oil. I would guess its the power stering line that leaks or even the brake fluid . Its nice to know that the product helped. Thanks LD
Old 05-20-2012, 07:08 AM
rdc rdc is offline
Russell
Today, I noticed only 2 small drops of less than 1/2 diameter. looks like the drops are becoming less over time. Perhaps this stuff does work given enough time/mileage.
Perhaps it may even help vanos seals.
Nothing negative regarding engine performace.
Old 05-20-2012, 09:14 AM
supertech777's Avatar
supertech777 supertech777 is offline
today, i noticed only 2 small drops of less than 1/2 diameter. Looks like the drops are becoming less over time. Perhaps this stuff does work given enough time/mileage.
nothing negative regarding engine performace.
+1
Old 05-20-2012, 10:50 AM
rdc rdc is offline
Russell
Sorry this a duplicate.
BTW, the drops of oil are getting smaller. Today there were two drops about 1/2 inch diameter each. No engine issues after about 1,000 miles. Perhaps this stuff does work.
Perhaps it will even help vanos seals
Old 06-05-2012, 08:33 AM
93tillInfinity 93tillInfinity is offline
Mein Auto: 93 525i
how's the oil drips coming along. I've noticed some small drips coming from mine as well and need a temp fix until money is available. Was thinking of using the Lucas Stop Oil Leak though
Old 06-05-2012, 08:35 AM
Mein Auto: 93 525i
I know i had used Lucas Transmission Slip on my Grand Prix i used to have and it worked. If it wasnt for that stuff my tranny would have went out along time ago.
Old 06-05-2012, 08:37 AM
Mein Auto: 93 525i
if i could pinpoint exactly where the leak is coming from that would be a big help. I think i'm going to use some degreaser and clean the engine up a little. It does look like there's a little leakage around the edges of the valve cover.
Old 06-05-2012, 08:50 AM
rdc rdc is offline
Russell
Down to one drop each day. I placed paper towels under the car and mark and date each day to see progress. I know, a bit over done.
Old 09-02-2012, 03:45 PM
lichtecht lichtecht is offline
Mein Auto: 2001 530i
Wondering if the oil leak stopped completely or down to a minimal amount that you can live with. Thanks
Old 09-02-2012, 07:52 PM
rdc rdc is offline
Russell
Glad you commented. Well I changed my oil. Leak seems to have come back. apparently there was not long lasting effect. Need to fix the leak. In this case White Sheperd was not sucessful.
Old 09-06-2012, 12:24 AM
BMWFatherFigure's Avatar
Old School
Some boby tell these guys about good / fast / cheap. You only get 2 out of 3.
