E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
Engine Flooding M52 New Fuel Pump
Well, I knew my two system fuel pumps had one foot in the grave. So i decided to install a High pressure intank pump and delete the old outside pump. To give my M52 a better throttle response.
Well the whole thing is installed, car runs great when at idle but when i went to see how it drove the engine just flooded. Anything faster the 3mph and its jerking and back firing. Could the fuel pressure regulator just called it quits when it worked before. Have any other ideas?
you may have to get an adjustable fpr.
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming |
Yeah i am gonna deal with it later. Stuck the old pumps back on and away i went.
Any ideas as to a good adjustable fuel pressure regulator? I see prices all over the place. 30ish-200ish. I really have no clue.
Hey, anyone know what the normal fuel pressure is for a m52?
about 3 bar. go high performance at 3.5 bar.
Thanks! I have it at 2.7 right now. Its not too happy if i do more. I'm pretty sure that will be fixed with the new fuel pump going back in. It pulsates with a hard dip. Check for vacum leaks but could't find any has a new boot and filter.
hows the valve cover gasket?
About 2ish years old.
could be that if it sat for a bit without running.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
