Old 04-19-2012, 09:23 PM
07841-tb's Avatar
07841-tb 07841-tb is offline
Mein Auto: 02' BMW 745li & 04 Rover
Trans Range N Only With Engine On"?
I drove my car to work and when i'm about to pull the key out, it's stuck in the ignition with a message Trans Range N Only With Engine On"? Anyone encountered this problem?
2002 BMW 745Li
2004 LAND ROVER RANGE ROVER HSE
Old 04-20-2012, 05:22 AM
wicky wicky is offline
Way East...
Mein Auto: To many cars..
had the same problem.. still dont know why...But that error message appeares sometimes even without the key in the ignition...
BMW E65 735iA 2003
Jaguar XJ6 3,2 1997
Mercedes 230CE 1983
No signature picture...
Old 04-20-2012, 06:46 PM
07841-tb's Avatar
Was your key stuck also?
2002 BMW 745Li
Old 04-21-2012, 12:03 PM
mikewerks's Avatar
mikewerks mikewerks is offline
Mein Auto: 02' 745i
I have had that message in the past. One thing I noticed, if I start the car with the drivers door open I will get that message 9 out of 10 times. The other way for me to get the message is to start the car move it a short distance then shut her down. I only get this message after the car has been shut off and same as you I have to manually eject the key. Since I started paying attention to not starting it with the door open I have yet to see this message. On a side note the first time I saw this message was after the car was reprogrammed and a fresh battery installed.
Old 04-24-2012, 09:03 PM
07841-tb's Avatar
Ok every one. I took the car to the dealership. they called me later today and said that i need a CAS control module. $1,200.00
2002 BMW 745Li
Old 03-08-2017, 08:29 PM
Runtime Runtime is offline
Mein Auto: BMW
I know this thread is a bit old but just wanted to update this forum with how I managed to fix the Trans. range N only with engine on error message!
Part Needed:
Valve Body Seal
BMW part number: 24 34 75 88 727
