Old 10-31-2014, 10:59 PM
haodang haodang is offline
Mein Auto: NA
noise from under the hood when the ignition is on
Hello all,
I recently noticed that when the ignition is on but engine is off, there is some noise coming out from under the hood. I found where it came from but do not know what that really is.
In the following video, you can see and hear there is a metal stick behind the plastic grids moving while generating the noise. The picture gives you an overview of where the plastic grids locate. The noise goes away after maybe 20 - 30 seconds.
Video:
https://drive.google.com/file/d/0By1...ew?usp=sharing
Picture:
Does any body have any idea? I appreciate your insights!
Thanks!
Old 11-03-2014, 11:54 AM
gfeiner's Avatar
gfeiner gfeiner is offline
Mein Auto: 2012 X3 xDrive35i
That is interesting. I will have to check mine when I get home. The area in your video and picture is the master brake cylinder and the brake fluid reservoir. You can remove the "plastic grid" for a better look by pulling up the rubber strips and then compressing the clip in the lower right hand corner of the "plastic grid" and pulling it up.
Old 11-05-2014, 04:33 PM
missedbass missedbass is offline
Mein Auto: 2012 x3 28i
looks like it is the wiper arm moving
Old 11-05-2014, 04:41 PM
Mein Auto: NA
But the wipers were still.
Old 11-05-2014, 04:46 PM
Yeah I don't get that unless there is a small amount of play before the wipers move
Old 11-05-2014, 04:50 PM
Mein Auto: NA
Thank you for your reply! But I don't think the wipers were active. So wipers were turned off actually.
Old 11-05-2014, 05:20 PM
There have been times when I shut the engine off the wipers move about an inch or so then go back to their normal position.
Old 11-06-2014, 04:36 AM
jeff_K jeff_K is offline
Mein Auto: BMW X3 28i
Yeap. Have seen that happened too. Seems normal with the wiper movement but not the sound as in the video.
Old 11-06-2014, 12:31 PM
Coder Coder is offline
Mein Auto: 2011 X3 xDrive35i
Don't know about the sound but do know that the wipers are programmed to move on vehicle shutdown every so often to keep them from sticking to the windshield. This is normal behavior.
Dave @7500 feet on the plains in Colorado
2011 X3 35i - Blue Water Metallic
