Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11)
Old 04-21-2012, 03:08 PM
Baquir Baquir is offline
BimmerLover
Mein Auto: 2012 528xi
Help...both fob remotes don't work
They both don't unlock/lock my car. And when I get in, I can't turn on the car or ignition unless I hold the key to remote, otherwise it gets me error message saying key not found etc.
Any thoughts ??
My car has only 2k miles
Current: 2012 528xi. Delivery date 03/13/2012.
Dark Graphite Metallic / Oyster-Black interior. Cold Weather / Premium / Technology pkg. BMW Apps. Rear fold down seats.
Prior: 2005 530i. Cold weather/Premium Pkg
Old 04-21-2012, 03:21 PM
azray7's Avatar
azray7 azray7 is offline
bimmerfest Supporting Member
Mein Auto: 2012 535i White M Sport
Change the battery in the remote or use your SOS button. Hopefully one of those options will work.
BMW CCA Member
2012 535i Alpine White, Cold Weather, M Sport, Premium, Premium Sound, Tech, Sport Trans
Old 04-21-2012, 03:36 PM
BimmerLover
It's both fob remotes not one , so can't be battery. Called up assist and roadside and they both said to call up dealer who is unfortunately closed.
Old 04-21-2012, 03:41 PM
azray7's Avatar
What good is assist if they can't help? Can you drive your car?
BMW CCA Member
Old 04-21-2012, 03:47 PM
TJPark01's Avatar
TJPark01 TJPark01 is offline
Mein Auto: F10 535/E92 335i
Change battery in remotes first. I had the same problem, yes, both can go bad.
Old 04-21-2012, 03:57 PM
BimmerLover
I can drive the car as long as remote is held near steering column.
Old 04-21-2012, 03:59 PM
BimmerLover
Thanks TJ. I will go to dealer Monday morning. I am still skeptical though re battery in that 2 fob key remotes will go bad at same time in under 2000 miles. I guess it can happen but I thought the chances of that happening now slim to none. Oh well.
Old 04-21-2012, 04:21 PM
TJPark01's Avatar
I went to dealer, got a loaner, did the whole schpeal. They replaced the battery in the remote. I kinda just wished I went to Riteaid and not had to go through the hassle.
Name:	Snapshot 2012-04-21 16-20-08.jpg
Old 04-21-2012, 05:28 PM
BimmerLover
Ok update. Dont ask me how, what, or why...but the missus and I went to have dinner at a restaurant, got done and fob worked just fine!!!!!!
Old 04-21-2012, 06:11 PM
Quacker Quacker is offline
Mein Auto: 2012 535i xDrive
Are you saying that the FOB was just hungry for power?
2012 535ix Space Gray, Cinnamon, SAT, Premium, Prem sound, Cold W., Sunshades, Gloss Black Grille, Gloss Black Side Markers, RE970AS 245/45/19 non-run flats that run very smooth + quiet and also correct the otherwise optimistic speedo
Old 04-21-2012, 06:24 PM
TJPark01's Avatar
Did you stay at a Holiday Inn last night?
Old 04-21-2012, 06:31 PM
BimmerLover
Quaker. I guess so!!!
TJ. No I didn't. But I did sort of abuse my car and take it to 90% of its potential in today's BMW CCA car control event. Turn off dsc/dtc; heavy ABS braking; 180 degree spins etc.
Coincidence??
Old 04-21-2012, 06:40 PM
TJPark01's Avatar
Coincidence??
none. It's meant for that. If you don't drive the car a lot or leave the key in the car, there is a tendency for the car to "stay awake" and not go into what is the equivalent of sleep mode, thus draining the battery both in the car and in the fob. Get a smart charger and swap the batteries in the key fob. It's a common problem with easy solution.
Old 04-21-2012, 07:00 PM
Diplomatic Diplomatic is offline
Check out the thread below, had the exact same thing happen two weeks after i got my car. Both remotes stop working after the car has been sitting in the sun. It worked fine in the morning and after sun set. My dealer had to replace the reciever in the steering column. Hope it helps
http://www.bimmerfest.com/forums/sho...315&highlight=
Old 04-24-2012, 09:41 PM
BimmerLover
UPDATE:
My dealer picked up my car for service Monday and dropped it off back at work today at noon stating that problem is fixed (battery replaced). I shared with my sa the forum thread posted by Diplomat above. He said he can't go by what's in the forum etc etc.
Anyways I parked the car at the top of garage in sun and at 5p I go to unlock door and fob doesn't work AGAIN!! So call and leave a frustrated VM and he calls back saying that he has opened a case with BMW, whatever that means, and that they will come pick up the car tomorrow again from me.
So let's see. Will keep you all updated as it progresses.
Old 04-25-2012, 10:08 AM
jygesq jygesq is offline
Mein Auto: 2000 528 MT
why don't they listen, you gave them the fix
UPDATE:
and BMW supertechs and super service advisors ignore it.
Old 04-26-2012, 07:32 AM
BimmerLover
UPDATE 2 (hopefully FINAL!!!):
So thanks to DIPLOMATIC (who emailed me a copy of the invoice), I used that to email it to the SA to advise them of this issue. A day later I get a call saying that "oh yeah we figured it was the FBD as well (YEAH RIGHT!!!) just like that dealer".
So long story short, part has been ordered, should be in by 2pm today and hopefully I will get the car by tomorrow.
Thanks to all of you, especially DIPLOMATIC for following with up so diligently.
Old 04-26-2012, 08:17 AM
DreamCar's Avatar
DreamCar DreamCar is online now
Moderator
Mein Auto: Future: F80 M3
Diplomatic/Baquir..
can you guys please post the service description here in this thread ...like the buletin number or the part numbers etc:- so that we can add this thread to out list of issues (Sticky).
It will be helpfull toour fellow festers if they come across the same issue.
Old 04-27-2012, 05:08 AM
BimmerLover
Yes I will. As soon as I get the car back and have the w/o with me.
Old 04-27-2012, 06:18 AM
Needsdecaf's Avatar
Needsdecaf Needsdecaf is offline
Everything's Bigger in TX
Mein Auto: 2011 535i
I understand your frustration, and have personally felt it when I have an issue that meets exactly some bulletin, TNN, TSB, etc. on my own cars.
I also see the dealer's side of it. 95% of the people who walk through the door are complete car morons, like the guy in front of me who didn't blink an eye at paying $1,100 for two new rear tires. Zoinks! They wouldn't know a service bulletin if it bit them in the ass.
Also, there is the process of approval and parts. You can't get paid for just trying something out. You've got to get permission to take action under warranty, esp. when expensive. And sometimes you simply can't get the right computer information (codes) to get the approval for the repair.
2011 535i
Sophisto Grau / Oyster - Black Nappa, Anthracite Wood
ZAV, ZCV, ZCW, ZDA, ZDH, ZPP, ZP2, ZSP
Mods - M5 Grilles, BMWPedals Black Anodized
Heaven is where the police are British, the cooks are French, the cars are German, the lovers are Italian and it is all organised by the Swiss.
Hell is where the police are German, the cooks are English, the cars are French, the lovers are Swiss, and it is all organised by the Italians
Old 04-30-2012, 01:13 PM
miguex miguex is offline
Mein Auto: 06 BMW M5 e60
Please can you post the BMW part number? I have a friend with his 528i F10 with same problem. Thank you!
Old 04-30-2012, 01:30 PM
Invoice attached...
