E90/E91/E92/E93 (2006 - 2013)
Old 04-23-2012, 11:58 AM
pantoine1084 pantoine1084 is offline
Mein Auto: 328i
Reverse Light Out.. LED Taillights Fix
Had error code for a light out since I purchased my used 07 328.. found out it is the back right reverse light.
Just had the car checked out and the mechanic did not know how to replace, or fix bulb (cause there isnt one) for the LED taillights. I have the smoked out aftermarket tailights, not sure of the brand though.
So... do I have to buy a whole new set of taillights? I am not familiar with how the LED lights differ from others. I just need to replace the reverse light.
ID:	322103   Click image for larger version
Bruce Wayne
Old 04-23-2012, 12:20 PM
tturedraider's Avatar
Freedom isn't free!!
The reverse light is a regular incandescent bulb. You'll need to take the trunk lid liner loose. Then there's a housing that holds the bulb. That housing snaps out and you have access to the bulb.
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." -- Geo. Orwell
Keep Right, Except to Pass
Then & Than usage - "It was hotter than ever (comparison). Then (time) it got cool."
2006 330i Sonora w/ ActiveAutoWerke flash tune - I like it!
2004 330i ZHP Imola/NB - missed
2000 328i TiAg - gone but not forgotten
BMW CCA member #388003 - www.bmwcca.org Use me as a referral, you could win a one day ///M Driving School!
Old 04-23-2012, 10:17 PM
Jason @ BMS's Avatar
Jason @ BMS Jason @ BMS is offline
Mein Auto: 07 E92 328i,11 135i,10 Fj
Here is the exploded view of the tail light. Looks like it is #9 - BMW Part # 63217160788
Old 04-24-2012, 06:08 AM
mflauer mflauer is offline
Mein Auto: 2004 545iA titanium gray
There are aftermarket LED reverse lights that plug right into the OEM tail light assembly which should be the same as your smoked one. Make sure it has a built in resister or else you'll get an error "reverse light out" with the standard LED. If that happens and the light is working it's easy to install a 6 ohm resistor across the connection.
Old 04-24-2012, 07:11 AM
Mein Auto: 328i
thx for the info guys.. seems like a DIY job (I say that reluctantly)
Bruce Wayne
328, led, replacement bulbs, reverse light, taillights
