E46 (1999 - 2006)
Old 04-23-2012, 07:28 PM
bigblueoval bigblueoval is offline
Robbie
Mein Auto: 325i
Expansion Tank Replacement
BMW..***** more tools.....
Ok, so I changed the expansion tank...upon crank up, it it leaking like crazy up top. There are 2 fittings on the top hose going to the motor..one goes to radiator, other small one goes to expansion tank. The snap ring is in good..I took it off several times and reinstalled it. QUESTION..Is there supposed to be an Oring inside the piece on the radiator hose that slide up over the small male fitting on the tank? Thats the only reason I can figure its leaking.
HELP
Robbie
Old 04-23-2012, 08:26 PM
RSPDiver's Avatar
RSPDiver RSPDiver is offline
Ich bin ein Bimmerer
Mein Auto: 04 ZHP/4
Hmm... If I recall the part I think you're talking about, then I think there is. But you might want to PM Smolck and/or add some pics to your question. Smolck has probably seen as many E46 cooling system refreshes as any BMW tech on any floor (read: not saying the service mangers) of any BMW stealership around. And he gives a rip, or he wouldn't be so active on here and in his community for DIY and maintenance support.
Old 04-23-2012, 09:20 PM
alpinweiss alpinweiss is offline
Mein Auto: E46, E83, E90 (all MT)
Yes, there should be an O-ring inside each hose end. If the O-ring is missing (or displaced), it would leak like crazy.
Alpinweiß
E46, E83, E90 (all with three pedals)
BMW CCA member
Old 04-24-2012, 06:42 AM
J. Kidd's Avatar
J. Kidd J. Kidd is offline
Coyote Racing Team
Mein Auto: 2011 Mustang GT
Make SURE it is pressed in tightly. I've done this twice and both times it initially leaked on me even though the snap ring was able to be pushed down and everything appeared to be nice and snug. Turns out I just needed to push it in a bit further. Once I did (it took a bit more effort), the snap ring was able to go down again and everything was fine. The difference can be 1/16-1/8" - that's all it takes. Good luck.
2011 MUSTANG GT
Premium / Brembo Pkg / 6 spd / 3.73s
Kona Blue with Black/Cashmere Leather
Steeda Sport Springs / Roush Axle Back / MGW Shifter / BOSS Front Fascia
