Old 04-23-2012, 09:32 PM
hale2thevictor hale2thevictor is offline
Mein Auto: 2005 BMW X3 2.5i
Question Decompression sound when turning off?
I am getting a decompression sound shortly after I turn my X3 off, it makes the same sounds as a turbo blow off valve. Does anyone have any idea as to what this could be???
Old 04-24-2012, 07:35 AM
niceguymr niceguymr is offline
Mein Auto: 2008 X3
Are you referring to this?
http://www.bimmerfest.com/forums/sho...d.php?t=584088
Old 04-24-2012, 08:20 AM
No, it is coming from the engine compartment. Like I said it makes a sound like a blow off valve and it is a quick release of pressure only lasting about 1.5 seconds. It sounds like it is coming from the drivers side of the engine compartment every time I turn it off.
Old 04-24-2012, 11:58 AM
lpcapital lpcapital is offline
Send a message via AIM to lpcapital Send a message via MSN to lpcapital Send a message via Yahoo to lpcapital
Mein Auto: Wasp & Duc
I know what you're referring to. I believe is the DISA valve that returns to rest position once the engine turns off.
Old 04-24-2012, 12:50 PM
So is it normal?
Old 04-24-2012, 12:51 PM
It sure is
Old 04-24-2012, 12:56 PM
Thank you Sir.
Old 04-24-2012, 07:06 PM
mlukas161's Avatar
mlukas161 mlukas161 is offline
Mein Auto: 03 330i, 04 X3
Hmmm, mine doesn't make a noise that I'm aware of. Have you looked into the CVV or oil separator? That may be a symptom... Just to play it safe, I would look into it.
Old 04-24-2012, 09:53 PM
tempestv8 tempestv8 is offline
Mein Auto: '03 530i Touring & '03 X3
I had a 530i Touring Wagon with the 6 cylinder M54 engine that behaved exactly the same.
The vehicle runs just fine, had loads of power and is very reliable. 220,000 kms on the odometer, and aside from unrelated oil and coolant leaks, this noise after shutdown that you are referring to has not caused any problems.
I suspect it's perfectly normal.
decompression sound
