09 750li Trany kicks from 20 to full stop. - Bimmerfest - BMW Forums
Old 04-24-2012, 04:52 PM
syavik syavik is offline
Mein Auto: BMW
Hello. 09 F02 not x drive transmission kicks when going from 20 to full stop. It happens once in a while on my vehicle. Do you have the same problem in your vehicle?
Thank you
Old 04-24-2012, 05:35 PM
dbs600 dbs600 is offline
Mein Auto: 2011 750LXi Individual
What does this mean; that when you put it into Park, it continues to roll a little before getting into gear (Park)?
Old 04-24-2012, 06:03 PM
Mein Auto: BMW
When you are driving 20 mph and coming to the stop.
Old 04-24-2012, 06:44 PM
Since new my transmission has had harsh downshifts from 3rd to 2nd and from 2nd to 1st gears, most noticeable when coasting, but after visiting the dealer numerous times, I've been told same is normal.
You seem to be experiencing something different. Sorry I cannot be of further help...
Old 04-24-2012, 10:07 PM
oneofew oneofew is offline
Mein Auto: 2011 B7 Alpina
Thank you
what you are describing sounds exactly like my wife's 06 Range Rover Sc, once we made a full stop it would kick, dealer reprogramed the trans few times and but could not get rid of the problem, finally dealer brought in a factory rep, he had them replace the rear diff and problem was solved once n for all.
I have not experienced that on my 7 series, that's not the norm.
Old 04-24-2012, 10:20 PM
I guess what you call harsh is all relevant, as i'm costing if the the radio is off in a quiet surrounding, especially cold morning, cold drivetrain, yes I can feel the downshifts. However if it's sifting harsh after heat soak, something is wrong, very likely the valve body of your new transmission could be calibrated a little off. You should test drive a brand new one see how that feels.
Old 04-25-2012, 06:25 AM
Mein Auto: BMW
Thank you
Thank you
Old 04-25-2012, 08:07 AM
chrischeung chrischeung is offline
Mein Auto: 2015 550i / 2016 MB C300
Did you try resetting the transmission? Google the procedure.
2015 550i ED - M-Sport, Exec, Heated Seats, Rear Shades - 4/9/15
2016 Benz C300
3/12 ED 7 - thread ID 610350
1/11 ED 6 - thread ID 5767556&postcount=175
4/10 ED 5 - thread ID 453501
5/08 ED 4 - thread ID 290679
3/07 ED 3 - thread ID 201013
3/06 ED 2 - thread ID 136454
Old 04-25-2012, 08:17 AM
Mein Auto: BMW
Looked, can't seem to find. Does anyone know?
Old 04-25-2012, 09:38 AM
http://forums.5series.net/topic/4001...moother-shift/
It worked for me in the past when I had my 2008 535i. I think the 2009 750 has the same or similar 6 speed transmission. Nothing lost other than a minute of your time giving it a try.
2016 Benz C300
Old 04-25-2012, 10:44 AM
AdamG13 AdamG13 is offline
Mein Auto: 2016 740Li
I had that problem with my 07 750. It was under warranty, so they replaced some type of electronic module on the transmission and it fixed things. I want to call it the ECM but I can't recall.
2016 740i Singapore Grey
2014 M6 Citrin Black
2013 750i Mineral White
2011 750i Jet Black
2007 750i Monaco Blue
Old 04-25-2012, 12:57 PM
canuckdon canuckdon is offline
Mein Auto: 2008 750Li
check out the e65/66 board, it's full of tranny issues, and the f01/02 has the same zf 6 speed as the e65/66 (2013 gets the 8 speed). No one has fully answered the question of why it shifts harshly, and worse yet, there is no single fix, and possibly no fix. People who have had a new tranny installed, say the harshness comes back in a few months.
Old 04-25-2012, 04:58 PM
Mein Auto: BMW
Ok, it's not that bad, so I'll deal with it I guess
Old 04-25-2012, 07:31 PM
DallasBimmer's Avatar
DallasBimmer DallasBimmer is offline
BIG D BIMMERS
Mein Auto: '13 535i MSPORT,'10 E93
Correct. I've had the same problem since last August and did the reset twice. It's good for a few weeks then gets harsh again.
Dealer here says there's no ECM flash for this one. They can flash the system but it won't correct harshness...
Old 04-25-2012, 07:33 PM
Is everyone writing about the 'transmission kick' syavik writes about or the 'harsh downshifts' I've mentioned?
Old 04-25-2012, 07:47 PM
Mein Auto: BMW
I guess, nobody else has this problem, not that there is a major kick.
Old 04-25-2012, 09:06 PM
Did you try the reset?
2016 Benz C300
Old 04-26-2012, 04:57 AM
Mein Auto: BMW
Yes, but trany didn't make any noise, possibly it's a different procedure. Can anyone else try resetting procedure?
Old 04-28-2012, 05:40 AM
kpumroy kpumroy is offline
Mein Auto: 2014 Audi A6
Please stop perpetuating the internet myth of a "transmission reset procedure". There is no such thing! The ZF 6 speed transmission has been and continues to be problematic. Part of the problem is the quest for fuel economy over performance and refinement in engineering and design.
Old 05-10-2012, 03:01 PM
Individual750LI's Avatar
Individual750LI Individual750LI is offline
BMW rocks!
Mein Auto: 2013 750I M
I tried the reset on my car yesterday, didn't have any noise from the tranny after pressing the pedal for 1 min. The car drives no different than before, well, not that I have harsh downshift anyway.
2015 X6M, 2014 X1, 2015 Kia Sedona SX-Limited
Old 05-10-2012, 03:24 PM
My personal experience says otherwise. I can't say there isn't anything inherently wrong with the transmission, but the procedure did smooth out the shift issue I was having.
2016 Benz C300
