E36 (1991 - 1999)
Old 04-24-2012, 07:53 PM
Killybeys Killybeys is offline
Mein Auto: 1993 325i
Exclamation Sucking noise made when gas is pressed
I have a 1993 325i and whenever i press the gas there is a delay in the accleration and it makes a sucking noise in the engine. It even makes the idle dip down slightly, about 200-300 rpm and its a manual so this is an annoying problem when trying to take off. Any help would be appriciated. i know it sounds like a vacuum leak but i have tried to find the leak with carbeurator cleaner and i cant find anything. Thanks
Old 04-24-2012, 08:04 PM
Ive also replaced the Idle control valve because i took it to a bmw shop and they said it might help, and that hasnt done anything. ive been searching for answers for months.
Old 04-24-2012, 09:51 PM
RhymeGrime RhymeGrime is offline
Mein Auto: 325iC
Check the intake boot for any cracks and make sure the O-Ring that connects the intake Tube (Or stock airbox if you're using that) to the MAF is still intact and in good condition. Report back for further diagnostics, I think you're on the right track about the air leak. The problem is the intake leak is probably only expanded or exaggerated by the rush of air when you push the throttle, so at idle that vacuum leak can't be identified since the vacuum pull is not great enough.
Old 04-25-2012, 07:52 AM
veteran011's Avatar
veteran011 veteran011 is offline
WARNING: Has Dumb Ideas
Mein Auto: 97 328is
using carburetor cleaner probably made your issue worse buddy. that stuff EATS rubber.... you may want to start replacing anything on the intake side that is remotely rubber.
dab of oppo anyone?
Project List:
Replace coolant temp sensor
Replace starter
Brake and Power Steering Fluid Flush
Front Control Arms, Bushings, and Tie Rods
Replace Passenger Lock Actuator
Reglue Peeling Hedliner
Swirl removal
Old 04-25-2012, 09:54 AM
Well it hasnt done anything to it yet so ill wait and see. And to RhymeGrime i checked it and everything looks ok, im going to take it off later and look at it from a full view rather than just glancing at it.
Old 04-25-2012, 10:00 AM
Moeman10's Avatar
Moeman10 Moeman10 is offline
hookersandblow
Send a message via AIM to Moeman10
Mein Auto: '99 M3
You have a vacuum leak somewhere, find it.
Originally Posted by petriej View Post
You can sleep in your car, but you can't race your house!
Old 04-25-2012, 10:33 AM
Ya im going to look over everything to do with intake today and see if I can find any major leaks. And I think it might be doing something to the idle as well, so hopefully I can kill two birds with one stone.
Old 04-25-2012, 02:16 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
I had a similar issue I was able to patch up with caulk and duct tape. Lasted about 6 months before I had to just replace the intake boot.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 04-25-2012, 02:50 PM
lenzhome lenzhome is offline
Mein Auto: 328iC
I just purchased a 1997 328iC and it was doing something very similar, but wouldn't hold the idle. It was the vacuum tube from the intake to the motor. Where it connects to the intake, the hose was cracked, but couldn't see it until it was disconnected. Replaced and it runs like a champ.
Old 04-26-2012, 02:49 AM
david656 david656 is offline
Mein Auto: BMW 323i E36 1995
Well, not wishing to go against the good idea's but my 323i had that symptom of breathing in, then accelerating - with the delay.
Amongst many issues it had this went away instantly after doing oxgen sensors and crank position sensor.
If you disconnect the batter and then let the ECU reset... after starting it again in the first few minutes is that problem still there? if not then it might be something other than a leak.
Old 04-26-2012, 04:16 PM
This hose is split and that about the only thing I found wrong with it. It's right below the main hose that goes from the throttle body to the air housing.
Old 04-26-2012, 05:02 PM
Mein Auto: 328iC
That was the one I replaced, and fixed the issue I was having.
Old 04-27-2012, 12:15 PM
Ok ill try and replace it then, it looks like a huge ordeal. did you do it yourself? or did you take it to a mechanic.
Old 04-27-2012, 01:19 PM
Mein Auto: 328iC
To be honest, first thing was to trim the hose below the crack and hook it back up. There seemed to be enough, and started it. If it holds it probably will be fine, or though a small hose clamp on it. And then I replaced it, which wasn't fun. But if the first works, great.
Old 04-27-2012, 02:33 PM
I disconnected everything and the sound is coming from underneath the intake manifold, so im thinking it could be that hose but the sucking noise is coming from under there so im thinking i might have to take everything off and try and find it then.
Old 04-27-2012, 03:17 PM
B_Rad_M3's Avatar
B_Rad_M3 B_Rad_M3 is offline
I6 feels good
Mein Auto: POS
It's your hidden turbo....
Check the gaskets, IIRC there are hoses under the intake manifold too... Maybe it's missing or cracked..
Old 04-27-2012, 04:31 PM
tchavera tchavera is offline
Mein Auto: 323is
spray carb cleaner down at the intake mani. sounds like the gasket is bad
Old 04-27-2012, 07:38 PM
After listening to it, the sucking noise its defenatly coming from under the intake manifold, i tried to find it without taking it out and i couldnt. so this weekend im going to take everything apart and find it. and ive tried to spray carb cleaner everywhere and it hasnt done anything so i need to take it apart and look.
Old 08-14-2012, 07:32 PM
deweyweekender deweyweekender is offline
Mein Auto: BMW 325i convertible
So I don't understand how carb cleaner helps you find a leak?!?
Also did you find any leaks? My '95 325 vert just started doing the same thing.
Old 08-14-2012, 07:39 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Spray the carb cleaner along each vacuum hose.
When the engine revs differently, you've found a vacuum leak.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
accelaration, idle, noise, pedal, sucking
