Old 04-25-2012, 01:10 AM
roboe1 roboe1 is offline
Mein Auto: 97 e38il
Is Bosch stage 3 injectors,Cosmo down pipe,stock exhaust, a good combination
I have the following parts but have not installed them because I'm not sure if it's a good combination or if I will need to change other parts so that everything works smooth
Any problems I might run into or parts that I would need to buy
Bosch stage3 injectirs
Cosmo cold air intake
Stock exhaust
Woul this flow correctly
Would a new maf be in order
Any tips would be appreciated
Old 10-25-2013, 02:04 PM
nihat nihat is offline
Banned
Mein Auto: BMW
Also interested, anyone have idea?
Old 10-25-2013, 04:51 PM
FABOCH's Avatar
FABOCH FABOCH is offline
Mein Auto: 2000 BMW 740I SPORT
I used a 4" O.D. Barrel, Cut the MAF stem off the OEM stock MAF, Epoxy`d the stem onto the Custom 4" barrel, Inserted the MAf Sensor, Installed Dinan bored out throttle body, M60(1995 e38) Larger runners Manifold, Dinan Free flow exhaust and its FLows likie a BAdd ass but you need 1 special thing....SOFTWARE!!!
I ihad to use Stage 5 Dinan Software to make it run right ($899)
2000 740i Sport , Alpina 21`, Alpina Lip, Alpina Deco kit,Dinan 7,Dinan TB, DINAN CAI, DINAN Exhaust, Dinan Stage 5, Dinan 4/5 transmission, Dinan manifold, Highline individual interior,Eibach/Bilstein,Zimmerman Timing guides 08/13
HTML code is Off
