X5 E53 (1999 - 2006)
The X5 SAV Forum |
is this the plug?
2000 x5 4.4.
I want to check the fluid level in the rear differential. I only see one square plug. Is this the fill in and drain plug? |
Also which fluid do i use? Also is the front transfer case have the same fluid?
There should be two plugs on the differential. There is a plug on the pass. side of the diff. The plug at the lowest point is to drain. The fill plug should be "mid diff" for checking.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
