Old 04-25-2012, 10:01 PM
Awestfield Awestfield is offline
Mein Auto: 2001 740il
still smoking after OSV replacement
hey guys i'm new here to the forum and the E38 world!!! I just recently purchased (about a month ago) a 2001 740il with 169k. It was smoking like a freight train on every start-up. so after reading numerous post about bad OSV's i replaced mine on sunday. When i pulled the old OSV off it seemed almost new however everything was covered in oil(i did the procedure without removing the intake manifold). now almost a week later i still have smoke on startup. The thing is i only get smoke after i drive on the interstate at the following startup or it sits over night... if i drive around town i'm fine with every following startup... any idea's do you think the cyclone seperator could be bad or could there just be that much residule oil in the manifold and the said hoses?
Old 04-26-2012, 08:35 AM
omnibus88 omnibus88 is offline
Mein Auto: 1998 740iL
It might be your Cyclone Oil Separator (COS). It's more work to replace though. Part is cheap (around $30) but in order to replace it you need to remove your timing chain covers. There is a hose that runs from front of an engine (COS) to OSV. When I was replacing my OSV, mechanic told me that if there is a lot of oil in that hose, (COS) needs to be replaced also. I am about to start this project myself and based on your mileage I would also replace timing chain guides while working at it.
Now, I'm not a mechanic but this is the info I got from my local shop that works on BMWs.
Old 04-26-2012, 08:44 AM
Yea thats what im afraid of which in turn will cost me more than i purchased the car for..... I have been readinf on e39 forums where 540i owners were bypassing the failed system using a catch can setup.... Has 740 owners had success doing this...
Sent from my SGH-T959V using Bimmer App
Old 04-28-2012, 12:40 PM
Going ahead with the OSV bypass tommorrow, we will see what happens... if that doesnt work than it's up for sale!!!!
Name:	2012-03-20 18.01.54.jpg
Old 04-28-2012, 07:35 PM
joyism5's Avatar
joyism5 joyism5 is offline
Mein Auto: '99 740IL, K75RT
It might be OSV or worn stem seals. Try using Mobil1 20W-50. That will reduce the smoke considerably.
JOY = BMW
Old 04-29-2012, 07:50 AM
Rulled out the stem seals with the amount of oil that is in the intake manifold... Will deffinately keep you updated after i finish bypassing the system today....
Old 04-29-2012, 05:03 PM
ok well got the cvv bypassed... no smoke!!!!!! but the pipe that connects the osv and the cvv has a crack in it and is causing a new issue... so looks like i will be pulling the intake manifold this week... this is interesting because the " best" Euro repair shop in the area told me the smoke was because the engine was blown....
Name:	2012-04-29 14.03.53.jpg
ID:	323102   Click image for larger version
Name:	2012-04-29 14.04.05.jpg
ID:	323103   Click image for larger version
Name:	2012-04-29 14.04.17.jpg
ID:	323104   Click image for larger version
Name:	2012-04-29 17.59.47.jpg
Old 04-15-2013, 01:35 PM
eternal740iL eternal740iL is offline
Mein Auto: 2001 BMW 740iL
Awestfield ... How is this setup working out for you? I am in a very similar situation and also recently purchased my vehicle. Did you also put a catch can in line with the valve and the breather filter in the pic? Is that venting the crank case well enough?
I am fairly certain that my cyclonic OSV (the unit near the timing chain) is gone. Since I recently replaced my PCCV and noticed a puddle of oil sitting in the rear of the intake manifold.
I was thinking of doing something very similar as I do not have the money to have the OSV replaced. I am planning on keeping the vehicle for a long time and would like to have a clean permanent setup that would resolve these oil in the intake mani issues.
So I was planning on doing the same thing, and with a catch can in line from the brass value. But instead of using a breather and plugging the center port in the PCCV, I was thinking of mounting a connecter there and having the hose from the oil catch can mount there. Im thinking that would provide plenty of vacuum to draw from the OSV (which is bad).. the catch can will catch the oil.. and gases will go back into the intake.
Am I missing anything? Would like to get this done ASAP. Any and all advice is greatly appreciated.
Old 04-15-2013, 04:26 PM
jitsjaf2009 jitsjaf2009 is offline
Mein Auto: 1995 325i Convertible
When I first got mine, I pulled the entire intake off and cleaned it (wow...lots of oil) and replaced all of the gaskets, including the valve cover gaskets. Did the OSV and found I did not need to replace the OS cyclone assembly (returned it). I am glad I did this...mine is a 1995 but only had 126k on it, but the intake and valve cover gaskets were drying out and cracking.
Old 04-15-2013, 11:45 PM
Moveitsmike Moveitsmike is offline
Mein Auto: 97' BMW 740il, 06' 330i
just goes to show you how much of crooks shops really are to take your money... you buy their trust and then they've got you by the balls.
Old 04-16-2013, 07:16 AM
Thanks for the info. Mine is a 2001, M62. Yeah I definitely plan on replacing the gaskets as well as the valve cover gasket. After I first got the car, almost a month now, I replaced the PCV w OSV which is the rear intake cover. When doing this, I noticed alot of oil in the intake manifold. I also noticed that the inner vent pipe was also completely dislodged from its correct position. This is the one that goes from the rear intake mani cover thru the interior of the intake mani to the front of the intake mani .. into a small hole which I believe eventually routes to the plastic intake piping behind the MAF. So I had to remove some of the intake piping in front and my throttle body. When I did this there was a good amount of oil slowly pouring out of the middle plastic pipe.. the one behind the maf that goes to the throttle body. I was able to reach thru the throttle body flange and dry/clean up much of the oil in the mani as well as correctly re-position the inner vent pipe. I also cleaned as much as possible by reaching in thru the back of the intake mani as well. Then I replaced the PCV as carefully as possible. This was about 2 weeks ago. I've already driven close to 1000 miles since then and yesterday my check oil level light came on and I was about a quart low on oil. I changed the oil about 3 weeks ago with full synthetic Mobile 1 for Euro, 0w-40.
So, at this point i am still seeing plenty of smoke on startup and am burning about a quart of oil in about 1000miles of calm highway driving. From what I've read and the amount of oil that was in the intake mani , I think there is a good chance my cyclonic OSV in front of the engine is not functioning well. Even if it is good... eventually it will go regardless and this is why I am interested in the oil catch can setup. As I mentioned I want to keep the vehicle for a long time and thus I am interesting in such mods that actually lower overall maintenance costs and efforts while not doing any damage. So this weekend I am planning on opening the front of the intake mani as i mentioned above and cleaning again and also double checking the inner vent pipe and also making sure that there is an O-ring on the end there since i didnt check for that last time. As well as going ahead with the oil catch can setup that i mentioned in the previous posts. I am relatively new to BMWs, but I personally do not see a down side to the setup and in theory I think it should work quite well as I am not really changing any of the normal vaccum flow of the sub system and really just kinda putting a catch can in-line so that oil is caught in the flow before it enters the rear of the intake mani... and doesn't build up in the intake mani and doesn't get into every other place it isn't supposed to. Of course i know I will have to monitor emptying the catch can regularly, but this is something that I can live with happily.
So I am really looking for anyone who may be able to validate or invalidate this catch can setup. Thanks again.. Any and all advice is welcome!
-eternal
Old 01-01-2015, 09:14 PM
FBOZZ FBOZZ is offline
Mein Auto: 1999 740IL
Awestfield-my e38 has the same problem you had I looked at your pics for the bypass. The vent with the filter is from the new fitting of the ocv? Where did you put the catch can? Is it between the filtered vent and the ocv? Do you recomend changeing the intake gaskets, valve cover gaskets and clean out the intake? Please advise me because I to would like to keep it for a while but if the expenses get to high I have no choice but put it up for sale. Mine is a 99 e38 with 144k in nice shape. Has a few quirks but I'm trying to get by. Electrical stuff like the indicator lite son the heating controls and the display on the mid go out but all works properly. Thanks in advance. FBOZZ
Old 01-01-2015, 10:35 PM
FABOCH's Avatar
FABOCH FABOCH is offline
Mein Auto: 2000 BMW 740I SPORT
Dont get all crazy about the cyclone ....Sure its more woerk but dont jump to that conclusion. I changed mOSV back cover plate and saw smoke for a couple of days and then it disappeared....Also you could have oil in the spark plug area...Have you opulled your back Spark plugs out yet? The 1`s closest to the windshield....I bet they r drenched in oil....
2000 740i Sport , Alpina 21`, Alpina Lip, Alpina Deco kit,Dinan 7,Dinan TB, DINAN CAI, DINAN Exhaust, Dinan Stage 5, Dinan 4/5 transmission, Dinan manifold, Highline individual interior,Eibach/Bilstein,Zimmerman Timing guides 08/13
Old 01-02-2015, 06:10 AM
No I haven't pulled the plugs. I did change the ocv a month or more ago and no change. Also changed the oil. Still no change. Engine runs smooth on startup even with the smoke. No miss fires. What's your opinion on the bypass in previous posts?
Old 01-20-2015, 08:55 AM
Mactavish Mactavish is offline
Mein Auto: 1995 BMW 740I
I had the same issue when I first bought my 95 E38... When I replaced my osv the smoking stopped immediately...I would do a compression test to see if you may have bad piston rings which would cause I to burn oil.
Old 01-20-2015, 01:42 PM
BMWFatherFigure's Avatar
Old School
eternal740iL - 0w-40 is WAY too thin for an E38. Check your hand book. The engine was NEVER designed with that oil weight in mind. Use synthetic (if you must) but 20w-50 is not unreasonable in your climate. No wonder you are burning oil. #ROFL#
Current:
E38 Parts Car
Previous:
Old 01-20-2015, 03:58 PM
Don't use 20-50 not even in his climate that's the worst weight oil u can put in a car...10-40 at the max but yes it does need to be synthetic...u need to troubleshoot the engine first tho...check ur codes and ur compression before u do anything else
HTML code is Off
