Old 04-26-2012, 09:31 AM
xugator xugator is offline
Mein Auto: Lexus
Comfort Keyless Entry System Question
I have read a lot about the comfort keyless entry system that is included in the premium package that includes the foot kick to open the trunk and touching the handle to unlock the door with your key in your pocket.
My question basically involves what the setup is for the base model and for cars that do not have the premium package (comfort keyless system)
Do those vehicles just get a standard remote with a lock and unlock on it? Is there a trunk release button on the standard remote?
Old 04-26-2012, 09:49 AM
tim330i's Avatar
tim330i tim330i is offline
Bimmerfest.com Founder
Mein Auto: Ti Silver 03 M3
It is the same remote either way, without the comfort access you have to lock/unlock the door with the key fob. There is a trunk button on the key.
Tim
energetik9's Avatar
energetik9 energetik9 is offline
energetik9
Mein Auto: 911 Carrera 4S
I had the previous model, but I think the system is the same.
Comfort Access (CA) has all the features you mentioned. Standard system is a key remote similar to any other key fob these days. You can lock/unlock with the fob and you can open the truck and roll down the windows. CA allows you to hit the start button without inserting the key (you just need to have it with you). The "regular" system just means you insert the fob into a slot, push the brake pedal and then hit the start button.
In short the standard system is no different than almost any other modern system on cars today. CA, just allows for more convenience.
Current - 2009 Carrera 4S
Current - 2010 128i convertible (wife's car)
Previous - 2009 M-sport 335i coupe
Previous - X5 3.0i with prem/sport
Previous - 2000 ///M roadster
Someone should invent a sarcasm font...
"In car rock, paper, scissors 911 beats Prius everytime."
Old 04-26-2012, 09:52 AM
Mein Auto: Lexus
Awesome info
Thanks everyone
Old 04-26-2012, 09:53 AM
tim330i's Avatar
The F30 3 series even without comfort access still has keyless go, meaning you never need to use the key to start the car. The F30 does not have a slot of the key to go in the dash.
Tim
Old 04-26-2012, 09:54 AM
Psycdude Psycdude is offline
Mein Auto: 2012 328i
I have the base model. There is no slot, you just have the key with you to start the car.
You push the button to lock or unlock, and when you it the trunk button the trunk pops completely up.
Old 04-26-2012, 10:29 AM
voip-ninja's Avatar
voip-ninja voip-ninja is offline
Swedish Murder Machine
Mein Auto: 340i x-drive
With comfort access, can you also lock the doors when exiting the car by touching the lock area on the door handle?
I'm actually a bit concerned that there is no backup key contained within the fob, which is what all of the other manufacturers do. How are you supposed to get into the car and start it in an emergency if the key fob electronics have stopped functioning?
Old 04-26-2012, 10:38 AM
tim330i's Avatar
Comfort access allows you to unlock the door by simply putting your hand in the handle and lock the door by touching the ribs on the top of the door handle. Very neat feature!
There is a key in the fob -
If the key battery dies you can use the physical key to unlock the door. Then put the key fob next to the steering column at the indicated location and start the car. Same technology that is in any electronic drive away protection key that has been used for 10+ years. Physically turning a key doesn't start the car unless the chip in the key tells the computer it is allowed. Turning a key or pressing a button is all the same if you think about it.
Tim
Old 04-26-2012, 10:40 AM
sr5959 sr5959 is offline
Mein Auto: 428GC M-Sport
Yes you can lock doors by touching the top of the handle, plus if you hold your finger there it closes windows/sunroof, which is pretty cool!
The keyfob does have a backup key in it which you can use to lock the glovebox, but I can't remember if there's a key slot outside the car.
Old 04-26-2012, 10:42 AM
voip-ninja's Avatar
I suppose I was confused by mention of "no slot". I understand now, thanks.
Wow you are quick Tim and your answers is better than mine!
Old 04-26-2012, 11:15 AM
OBS3SSION OBS3SSION is offline
Mein Auto: '02 M3 'Vert
With the CA feature, you can unlock the car, get in, start it and drive away without ever having to touch the key. My question is... what is the range of the key? I typically hang my keys on a key-rack just inside the door from the garage to the house. It would pretty much suck to drive away and forget the key at home!
On related notes, what prevents another person from opening a door while you are trying to get into the car? (The typical woman in a dark parking lot scenario.) Or what happens if you get out of the car while it's running?
Eric (the Obsessed)
2002 M3 Convertible
2005 VW Passat 1.8T Wagon
Old 04-26-2012, 11:58 AM
tim330i's Avatar
The range of the key for CA is rather short, a couple feet at most. It is also oriented so it know which side of the car the key is on. If the key is on one side of the car you cannot put your hand in the handle and unlock the car from the other side.
If you get out while the car is running it continues to run. There are cases of Bimmerfest members starting the car then leaving the key and getting stranded.
Tim
Old 04-26-2012, 12:04 PM
zeezz zeezz is offline
Mein Auto: 2012 328i Sedan
Tim
While we're at it - does the car beep or alert you when the key is removed from the proximity of the interior and the engine is still running? On our Lexus and Mazda, the car starts beeping like mad when it doesn't detect the key anymore - it doesn't kill the engine, but it definitely gets your attention.
Old 04-26-2012, 12:13 PM
tim330i's Avatar
Yes, it does alert you. That might be a new feature on the F30, not sure.
Tim
Old 04-26-2012, 01:16 PM
voip-ninja's Avatar
On the rental my wife and I had, we got a warning pop up on the i-drive screen that warned us when we opened a door that the ignition had not been shut off. The car is so quiet it is very easy to leave the car running and not even realize it.
It would be nice if the CA feature automatically shut the engine off and possibly locked the doors if someone gets out with the key and walks off.
