Old 04-27-2012, 07:23 AM
bowlergal bowlergal is offline
Mein Auto: 05 X3
2005 X3 3.0 front windshield washer not functioning correctly.
Recently, I my front windshield washer stopped working. When I attempt to push it, I hear the sound that it's working but only a small amount of fluid comes out and it has a very small stream down the hood. It doesn't "shoot" up on the window. The rear mechanism works fine.
Anyone out there have any suggestions? They would be greatly appreciated. Thanks!
Good News! Windshield washer not working problem solved After going through the process of checking the washer pump(which was working fine), and cleaning out the filter, the system worked fine while the hood was up. When I closed the hood thinking everything was good, the washer fluid stopped working again. Opened the hood to take a look again and discovered something most unusual that was causing the problem all the time. The hose running from the washer fluid container was being pinched by the hood hinge whenever the hood was shut. I simply moved the hose slightly to the right and it worked just fine. So, the problem was caused by the hoods hinge pinching the hose thus preventing washer fluid from passing through it.
Last edited by bowlergal; 04-30-2012 at 05:34 PM. Reason: 2005 X3 windshield washer problem solved
Old 04-27-2012, 07:37 AM
AzNMpower32's Avatar
Tar Heel Faithful
My guess is a failing washer fluid pump. Easy to replace, costs about +/- $65. Part number should be: 67 12 8 362 154
Current consumption: Spritmonitor.de
Old 04-27-2012, 08:12 AM
dogpile dogpile is offline
Mein Auto: 2008 E83
Here is a link to a previous thread.
I replaced mine with an EBay 10 buck pump and it works fine. The installation will take you 15-30 minutes, easy job....
See my posts in this thread for more info!!
http://www.bimmerfest.com/forums/sho...815&highlight=
Old 04-27-2012, 01:40 PM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
Thumbs up
Do a search. I just replaced mine. Got the OEM pump and replacement grommet off ebay $12.95 shipping included 5-10 minute job. Good luck PS make sure you get the same contact pins as the one your replacing. They come round or flat.
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Mats-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Mats
Old 02-23-2013, 06:26 PM
chingerbunnies chingerbunnies is offline
Chingerbunnies
Mein Auto: 2005 X3 and 2006 325cic
Which pump is for the front washer? Or should I just replace both even though the rear works fine?
Old 02-24-2013, 09:31 AM
Have someone pull on the leaver while you stay by the pump. You will hear the pump working in conjunction with what leaver you pulled. Good luck
cheers
vern
Old 02-24-2013, 11:47 AM
John320 John320 is offline
Mein Auto: 2017 X1
some instruction if you need it -
Old 02-24-2013, 02:47 PM
Chingerbunnies
Thanks, ordered washer pump and will give it a shot when it gets here.
