Problems with opening z4 roof manually - Bimmerfest - BMW Forums
Old 07-06-2016, 01:51 PM
solix66 solix66 is offline
Mein Auto:
Hi, I don't want to replace the motor or fix anything I just want to be able to open and close the roof manually. The motor slowed down and finally broke. The Microswitch if fine latches unlock and everything is working other than the motor but it seems like that red handel is not working. roof wont retreat more that 4 inches. Does anyone know what's wrong with it? Again I'm not thinking about fixing it, just want to open and close it manually because I park outdoors and it won't take long until this happen to a new motor again
Old 07-06-2016, 01:58 PM
Mein Auto:
Originally Posted by solix66 View Post
Z4 2005
Hi, I don't want to replace the motor or fix anything I just want to be able to open and close the roof manually. The motor slowed down and finally broke. The Microswitch if fine latches unlock and everything is working other than the motor but it seems like that red handel is not working. roof wont retreat more that 4 inches. Does anyone know what's wrong with it? Again I'm not thinking about fixing it, just want to open and close it manually because I park outdoors and it won't take long until this happen to a new motor again.
Old 07-06-2016, 02:06 PM
Mein Auto:
It moved easily and i was able to close it very smooth right after the motor died. but that was the only time that it actually worked.
Old 07-09-2016, 04:59 PM
manana manana is offline
Mein Auto: Triumph Spitfire
Solix 66. I found pulling out the handle and rotating it did not totally disengage the hydraulics; it needed to go further. I just put a small bungy chord from the handle to a hole further right in the trunk; lined up great. Ran like that for a few years.... that top gets heavy after awhile
Just did the motor a few weeks ago, and the handle still doesn't disengage the hydraulics.
Good luck.
Steve
Steve
2001 Honda Prelude
1978 Triumph Spitfire
2008 BMW Z4 3.0si Roadster
