Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E28 (1982 - 1988)
E28 (1982 - 1988)
Old 04-28-2012, 08:22 AM
BBond528e BBond528e is offline
Mein Auto: 1988 528e
Speedometer
I have an 88 528e. The speedometer only works when it wants to. Sometimes it will work sometimes it wont. Also sometimes i will go from 0 spike up to speed then cut out again. Not sure what the issue is can anybody help?
Old 06-04-2013, 09:01 PM
Drift4 Drift4 is offline
Mein Auto: Tricycle
speed sensor in the back of the rear differential usually goes bad. ohm test it if it in the proper resistance values. check your bently book
Old 06-06-2013, 03:10 AM
Piston_broke's Avatar
Piston_broke Piston_broke is offline
What was that noise??
Mein Auto: E28 M535i, E30 323i
If the above doesn't help then try replacing the decades old, plastic cogs within the gauge assembly.
Pretty easy job, I've done it on my old E30 and about to tackle on my E28. Just go easy and don't break anything.
$17 will hopefully see you with a better and working speedo.
http://store.garagistic.com/ocart/bm...odometer-gears
He's very helpful and knows our cars gauge workings. Read the reviews if you've got time.
Cheers,
PB
Old 06-06-2013, 04:01 PM
garagistic's Avatar
garagistic garagistic is offline
Mein Auto: e30
Pm us about the odometer gears. We take care of the bimmerfest members.
Old 08-05-2013, 01:21 PM
rxbike rxbike is offline
Mein Auto: 84 533i, 03 996 TT,
Looks like I am in need of those gears for my newly acquired 84 533i from my friend's barn.
Are the cluster difficult to remove from the dash ?
Old 08-05-2013, 02:18 PM
garagistic's Avatar
Mein Auto: e30
PM sent.
HTML code is Off
