E46 (1999 - 2006)
Old 04-28-2012, 02:37 PM
angie_7gl angie_7gl is offline
Mein Auto: BMW 325
Post Key Fob not working... works when it wants...
My key will sometimes work and other times not work to unlock/ lock doors... When it locks, gas door will not open.. I tried reprogramming by doing the pressing the lock key button, but still won't work... I checked the fuses in the glove box, they are fine. I thought it might be the battery, since it sometimes works, but I was told that can't be it, as the battery charges when you put it in the ignition.... Can anybody help...??? Please! Any suggestions????????
Old 04-28-2012, 02:50 PM
bmwtech78 bmwtech78 is offline
Mein Auto: anything not german
Sounds like the general module. Have you checked for any fault codes? If you have faults for central locking relays you need a new GM.
Sent from my R800x using Bimmer App
Old 04-28-2012, 03:00 PM
Mein Auto: BMW 325
hmm.. I have not checked for that.... ummm where and how do i check for that??????? Thanks so much for your help by the way....
Old 04-28-2012, 03:06 PM
Baquir Baquir is offline
BimmerLover
Mein Auto: 2012 528xi
Had same problems in f10. Check out the thread in the 5 series forum.
Current: 2013 535xi. Space Gray / Venetian Beige interior. Cold Weather / Premium / Technology pkg / Driver Assistance / HUD / Comfort Access. BMW Apps.
Prior: 2012 528xi. Delivery date 03/13/2012.
Dark Graphite Metallic / Oyster-Black interior. Cold Weather / Premium / Technology pkg. BMW Apps.
2005 530i. Cold weather/Premium Pkg
Old 04-28-2012, 03:11 PM
Mein Auto: BMW 325
I will.. thanks!!!! =)
Old 04-28-2012, 05:34 PM
rgk330i's Avatar
rgk330i rgk330i is offline
Mein Auto: 2013 335i M-Sport
See www.bmwgm5.com for an overview of the GM5 general module and the problems with the locking relays. If all doors (and the fuel filler door) lock but fail to unlock from both the key fob and the interior key, your problem is likely the GM5 relays. Otherwise, probably it's something else.
2013 335i M-Sport, ED May 2013
key, key fob, lock, unlock
