Old 04-27-2012, 05:25 PM
Hazem_abdulrab Hazem_abdulrab is offline
Mein Auto: 2001 BMW 740i
Adaptive mode won't change gear
Problem with the e38 it won't get out of gear . It stays stuck in gear . It was driving fine . Then I raced someone and after awhile of driving i felt it stay in gear it wouldn't change gear in adaptive mode
Old 04-27-2012, 06:09 PM
So I disconnected the battery and connected it back on and drove the car and it reset itself so it was driving and changing gears just fine. Then it came back on again after driving for 20 minutes this time I was driving normal. Anyone have any idea what this could be ? It's a 2001 745i
Old 04-28-2012, 12:36 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Not enough info to make suggestions. Which shiftgate/tranny set-up do you have...STEPTRONIC (PRND M/S +/-) or the PRND432 with A M tranny switch?
PRND432 w/A M tranny switch
PRND M/S +/- STEPTRONIC {this is an e39...but STEPTRONIC gear shift is the same}
And is the correct gear appearing in the "gear display" on the lower right side of the instrument cluster when the tranny is shifting correctly...and how about when it is not shifting correctly?
"gear display" - PRND S 432 display in image below
(will vary depending on if you have STEPTRONIC or PRND432 gear shifting)
Q {BMW CCA Member #191509}
(SOLD)
Old 04-28-2012, 01:47 PM
I have the PRND432 with A/M. It's on drive. On A mode . It left for now but I'm sure it might come back on. I have a tire defect display message and I'm not sure what that's exactly for. I did recently change the front left strut but it still shows the message . I start the car and it's fine no display messages but when I start driving the brake,abs, and traction light all turn on after a minute of driving
Old 04-28-2012, 01:50 PM
Now as far as the trans I don't think it's mechanical it could be electrical ? Or a bad sensor?
Old 04-30-2012, 02:02 PM
NM740iL NM740iL is offline
Mein Auto: 740iL
I had the same thing happen and the dealer diagnosed a bad switch for the A/M. They replaced the switch and all is well since.
HTML code is Off
