First BMW F30 Recall - Front Headrest Height - Page 2 - Bimmerfest - BMW Forums
Old 07-31-2012, 05:46 PM
Elk Elk is offline
Mein Auto: ~
Originally Posted by vern View Post
Nobody disturbed by not being able to bring the head rest flush to the seat back?
Nope.
Old 07-31-2012, 05:57 PM
voip-ninja's Avatar
voip-ninja voip-ninja is offline
Swedish Murder Machine
Mein Auto: 340i x-drive
The entire reason they did the recall is that testing showed that in the lowest position the headrest whiplash prevention was not working properly. I'm not sure exactly why someone would go to the length of disassembling their car to override a safety feature.
** Removed - Tim330i **
Old 08-01-2012, 06:44 AM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
I'm not trying to override the safety feature. Right now the head rest in the full down position with the 2 notches showing, the bottom of the head rest is even with the top of my head. If I could move the head rest to be flush with the seat back the head rest would be in the center of my head where IMO it should be to get maximum safety Now maybe you can understand why I want to move it. Besides you will get better vision looking out the rear window passenger side when siting in the drivers seat.
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Mats-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Mats
Old 08-01-2012, 07:01 AM
voip-ninja's Avatar
Thanks for explaining Vern. I mistakingly thought that it was the lowest position that caused the problem, but it is the highest position that has the issue.
Does anyone know if they have continued doing this hose clamp fix from the factory or did the engineers come up with something more elegant on the newer build cars?
Old 08-01-2012, 11:24 AM
If you go on BMWNA site and build your car you will see it looks much better with the head rest flush with the back rest.IMHO
cheers
vern
Old 08-01-2012, 11:05 PM
NewToCarBuying NewToCarBuying is offline
Mein Auto: AH5 "13
This was just another way they used to prevent locals to buy foreign cars
What is the Start Stop Service i never got notification about that
Old 12-19-2012, 06:24 PM
larryshomework larryshomework is offline
Is this your homework?
Mein Auto: 2009 335i
Just removed my headrest on a 2013 328i with sport seats (M-sport - leatherette). The clamp is gone. It is replaced with a torx (T30 I believe) screw in the bottom of the left post (drivers side seat) - the post with the release/adjust button. I had to do the mod on the other post to lower the headrest flush to get access to the torx screw.
FYI I had a hell of a time getting the seat back clips out - I used a set of pliers and ended up breaking them both.
http://filmyear.typepad.com/photos/uncategorized/2007/05/11/lebowski.jpgIs this your homework Larry?
2008 Porsche Boxster (White/Tan/Brown, 5spd)
2003 530i (Titanium Gray/Black, auto)
1990 325iC (Red/Tan, 5spd, convertible)
Old 12-20-2012, 06:27 AM
Thumbs up
Do a search!!! There is complete write up how to lower the head rests. 5 mimute fix without removing the seat back.
Good luck
cheers
vern
Old 12-21-2012, 01:02 AM
pitzerwm pitzerwm is offline
Mein Auto: 335i Sedan
I just bought a 2012 335i and the recall wasn't taken care of (its been on the lot for 10 months)(Tim Bush BMW Richland, WA) So I take it in tomorrow. Their excuse for not doing it, "well we don't pay a lot of attention to these, that are on the lot". Counting all the things that have "turned up" as a result of my purchase, this might turn out to be the biggest mistake that I have made in a long time.
Old 12-21-2012, 06:55 AM
chiba chiba is offline
Mein Auto: BMW!
Arrow
Good luck
cheers
vern
I think I found the post your talking about.
http://www.f30post.com/forums/showthread.php?p=11916802
Looks like you need to repeat the process every time the rest gets adjusted up and you want it to go back down again..
Old 12-21-2012, 08:39 AM
Thats one of many posts on the head rest. You will have to repeat the fix every time you adjust the head rest unless you remove those two little springs on the part that you push in to enable the head rest to go down. I didn't do that because I don't move them any more once there in the down position. Good luck
cheers
vern
Old 12-29-2012, 11:23 AM
Good luck
cheers
vern
I needed to remove the headrest for a separate reason - therefore, I needed to remove the screw (clamp in older versions) to pull the head rest. I was updating the process for removing the headrest - not for lowering the headrest.
bmw f30 headrest recall, bmw recall, f30 bmw recall, headrest
