Stuck and stripped o2 sensor bolt/nut. What should I do? - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 04-30-2012, 07:32 PM
vicdroid vicdroid is offline
Mein Auto: 1998 328i
It appairs that these o2 sensor may even be the originals from 1998, the guy I bought it from had NEVER done any manteinance to this car. So I'm stuck with all the homework.
I already sprayed PB blaster LOTS of it. Left it alone for a while. Ran the car so they would warm up. Blow torched the **** out of it. And after all this the nut ended up getting all stripped.
What should I do at this point?
Thanks for your help in advance.
This is how both o2 Sensors look like...
Old 04-30-2012, 07:45 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
What part did you heat up? You're supposed to heat the pipe it's in, not the nut/sensor. Expand the outside part, not the piece that's in it. Heat the pipe and the fitting the O2 sensor screws into RED hot, but try to keep the heat off the sensor itself as much as possible, then go after the sensor with Vice-Grips as tight as you can apply them. This will probably be best done with the pipes OUT OF THE CAR.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 04-30-2012, 08:00 PM
Gooby's Avatar
Gooby Gooby is offline
Sexy Sax Man / Kebab Lord
Mein Auto: 1995 M3
You could probably have an exhaust shop cut it out and weld a new bung in place. It should cost like $20 for labor and a new o2 sensor can be had for ~ $50-100 depending on how mechanically inclined you are.
Instagram | @randytheus
Old 05-01-2012, 10:23 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Mine were on pretty good, too. I had to use a bar to get enough torque on my wrench. It looks like yours are boogered up, though. Vice grips might be your only option sans cutting it out.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 05-01-2012, 12:29 PM
RhymeGrime RhymeGrime is offline
Mein Auto: 325iC
Didn't you use the o2 sensor wrench from auto zone?? It's impossible to strip it with that wrench, what exactly did you use to get it so fakked up?
Old 05-01-2012, 02:53 PM
jaguarx7 jaguarx7 is offline
DON'T PANIC
Send a message via AIM to jaguarx7
Mein Auto: 1994 325is
There is still enough there to bite if you use the right tool. Might try using a hammer and chisel or punch, whack the thing a few good times, and see if the shock will break it free. If you have a friend with an air compressor and an air chisel the sensor would be out in seconds.
Cars are much more compact if you don't take them apart.
There is a theory which states that if anyone ever figures out how and why the universe came to exist it would instantly dissapear, and a less rational, more complicated one would replace it.
There is another theory which states that this has already happend...
Old 05-01-2012, 03:01 PM
Hellawut??
Mein Auto: who knows?
fuuuuuu
this is what i forgot to buy at the parts store today.
Ughh
-Franklyn
Old 05-01-2012, 05:37 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
yeah, about those...they're ok for some instances, but for really stuck on units, they are like a cheap date. too easy to spread.
as ken suggeted, heat the pipe up red hot and then apply torque to the sensor.
worst case scenario, cut the wires and slip a box end wrench on it.
btw, i like the 1st sample, not the 2nd...
df
Name:	sensor socket.jpg
ID:	323306   Click image for larger version
Name:	o2 socket.jpg
Old 05-02-2012, 06:40 AM
veteran011's Avatar
veteran011 veteran011 is offline
WARNING: Has Dumb Ideas
Mein Auto: 97 328is
this is gonna be good!
dab of oppo anyone?
Project List:
Replace coolant temp sensor
Replace starter
Brake and Power Steering Fluid Flush
Front Control Arms, Bushings, and Tie Rods
Replace Passenger Lock Actuator
Reglue Peeling Hedliner
Swirl removal
Old 05-02-2012, 09:08 PM
Hornhospital: I did burn the pipe but there were no redhot metals. These o2 sensors are old and are getting replaced so it doesnt matter if they get extra hot.
KaptinKP: I got the replacement Bosch o2 sensors for 75 bucks. All I'm trying to do is take the old ones off. And I would have no clue on how to remove the pipe. So I will leave that as my last resort.
petriej: I did use a bar to get better torque and it just kept slippin
RhymeGrime: I did and it fited perfectly but as I pulled it just ****ed it up. Then I tried the grips and that just made them worse.
jaguarx7: I do have an air compressor but not the tool, so Ill just go oldshool with the hammer and chisel.
drivinfaster what sup, thanks again for the help. I saw those sockets at autozone but didn't think either would help with such little room to use them. But I can defenatelly buy one and try it out .
veteran011: Lul
Everyone thanks for the help. Sorry I took a while to reply I spent the weekend at Dells, WI. I'll try all these tomorrow and report back with my findings.
Old 05-02-2012, 10:29 PM
D'oh, You Kids!
The purpose of heating a stuck threaded joint is to expand the piece holding the part that's stuck in it. That will loosen the fit enough that hopefully the piece will unscrew, but you have to get the outside piece at minimum RED hot.. Keeping the heat on the outside part and off the sensor as much as possible keeps the sensor from expanding as much as the outer pipe.
By heating both pieces you were defeating the whole purpose of using heat. You just as well have not used the torch at all. I know you can't help getting the sensor hot to some extent, but concentrate the heat on the pipe.
Quotes to live by:
BMW-CCA #441426
Old 05-03-2012, 06:44 AM
veteran011's Avatar
Mein Auto: 97 328is
I'm replacing the pre-cat o2 sensors this weekend. I'm gonna take this thread as a list of things to avoid. haha. good luck dude. KP may be on the right track though. dropping the mid-pipe will give you more clearance (and leverage) and hopefully let you get a better grip.
dab of oppo anyone?
Project List:
Replace starter
Swirl removal
:3, oxygen, rusty, sensor, stripped, stuck
