Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series
3 Series & 4 Series
The BMW 3 Series and 4 Series Forum. If you would like to see all new posts in all the forums, click here.
Old 05-02-2002, 07:09 PM
virtualrain's Avatar
virtualrain virtualrain is offline
Mein Auto: '01 x5 4.4i; '02 330Ci
My Nav Volume Findings...
Since this was part of a thread that was getting off topic, I've started a new thread....
After spending a good amount of time experimenting with different things, here is what I have determined. I would be interested in knowing of others can verify this. (I have 3-1/50 on a 2002 MKIII Nav system - car produced late Feb. 2002)
First some definitions...
Nav Volume - the actual volume of the lady's voice
Main Volume - the volume of the radio/tape/cd
Nav Volume Setting - the volume setting on the Settings Screen
My findings...
1. Nav Volume varies with Main Volume - although subtle, there is a noticable difference in the lady's voice between a low main volume and a booming main volume.
2. Nav Volume Setting affects Nav Volume - again, although subtle, lowering the nav volume setting DOES affect the nav volume. It's easiest to notice this by setting the main volume really loud and trying both a low nav volume setting and a high nav volume setting.
3. Nav Volume Setting affects attenuation level of radio/tape/cd - When the nav volume setting is on the highest level, the other audio source is totally cut when the lady's voice comes on. About three or four notches down on the nav volume setting, the audio becomes attenuated and the lower the nav volume setting the less attenuation is provided. With the nav volume setting at the lowest level, there is almost no change to the radio/tape/cd level when the lady's voice comes on and her voice is also quite low in relation (see point above).
Similar Threads
DVD Nav Problems delgal 3 Series & 4 Series 14 05-08-2003 07:13 PM
Nav software list - question for nav geniuses RS2 General BMW Questions 2 04-07-2003 11:31 PM
New dilemma: NAV system or SAT radio fstubbe Ask-A-BMW-Dealer 5 09-30-2002 06:28 AM
Temporary Fix For Nav Volume by Dealer rwebbe 3 Series & 4 Series 1 06-29-2002 08:34 AM
HK speed sensitive volume adjust w/ NAV? punkman79 3 Series & 4 Series 22 05-02-2002 07:10 PM
