Old 05-02-2012, 04:22 AM
mokh mokh is offline
Mein Auto: BMW 735 2002
fm radio static in and out!
hey there,
first of all i have searched this forum and other forums for my problem but couldnt find a solution, if i happened to overlook something please point it out,
thank you.
my problem....
i left the car parked in a garage for around 15 days when i went abroad for a business trip, when i came back everything was in good working order except for the fm radio! all i get now is static! i have an e65 735i 2002, european version with factory tv. everything else is working just fine, although the cd player does tend to stick every once in a while. AM radio is working perfect, tv reception is good and cd is fine.
FM radio on the other hand comes and goes, most of the time its static, but sometimes it works perfectly for around 20 mins then it goes back to static.
Anyone has any thoughts on the problem? is it an antenna connection issue?
thx in advance.
Old 05-02-2012, 06:06 AM
1bad540's Avatar
1bad540 1bad540 is online now
Its either your fm connection or the antena that is built into the rear glass, does the static get worse when you turn on the rear defrost?? If so its the antena in the glass.
[SIGPIC]
99 540i sport, acs type 2's chrome, acs spler pdls,Euroclrs
04 745i aw sport,21's aib's acspedals& rf splr(sold)
00 328i Prem Aw18" 335spt whls(sold)
02 Corvette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav
05 X5 3.0, pana rf,nav,xenon,cldweather, premium.ipod hookup, 20"4.6rims staggered 315rrs.
06 750I aw, sport. chrome21's,acs pdls,acs rfsplr,mtecs,8k hid fogs,Leds.oem ipod&sirius
03 VIPER, forgelinewheels,tune,exhaust,intake.
Old 05-02-2012, 08:55 AM
SFbay SFbay is offline
Mein Auto: BMW 745i
Ask or L7
Old 05-02-2012, 01:57 PM
1bad540: i tried turning on the rear defrost with radio on tday...same thing. but the thing is thats its ONLY static....when it works it works perfectly nd when it doesnt its only static with no radio whatsoever
sfbay: its ASK. i had L7 enabled through ncsexpert but i dont have the hardware to support it so all of the options are there but i cant tweak anything.it was working when i did this so i dont think that it caused the problem.
Old 05-03-2012, 06:41 AM
any additional thoughts? where can i find this antenna connection?
Old 05-03-2012, 06:51 AM
1bad540's Avatar
I know on the e39's it was behind the sail panel on the driver side by the back seats, maybe theres an online diagram. If your getting only static with the defrost its most likely the antena. I had this problem and the back glass was replaced. check the lines in the rear glass for a cut.
[SIGPIC]
Old 05-03-2012, 12:47 PM
i'll check them in a bit....but i didnt replace the glass...i'll check the service manual for other connections as well.
Old 10-07-2012, 02:52 AM
tabuarasa tabuarasa is offline
Mein Auto: E65 745i (2002)
I have exactly the same problem.
can you please inform how do you solve that.
thanks in advance.
Old 10-07-2012, 03:08 AM
i didnt :S
I still dont have a radio its completely static now on all channels. I checked the fm tuner in the left pillarand the wires in the rear glass...everything seemed to be in order so i gave up.if you have any suggestions iplease share
Old 10-07-2012, 09:43 AM
TUF-FKR TUF-FKR is offline
Mein Auto: 2002 BMW 745i
I would say its an ASK problem. I get the same symptom occasionally. I noticed when it is exhibiting the static (no other noise), the Idrive spins smoothly and the MMI doesnt keep up with the rotation of the Idrive. Meaning there is a LAG in communication. I restart the car, or just wait 20 minutes, and the problem clears itself. I always assumed it was the ask. I just have dealt with it since it happens about once every 2 months. Let me know what you find, also does your Idrive exhibit weirde behavior when the problem happen?
Old 10-08-2012, 08:12 AM
in my case the following happens:
FM radio: start the car and all is OK, passed some time +/- 15-20 minutes came cracking noise from speakers and the list of receivables stations are empty, not the memorized ones, and finaly no sound. Restart the car and the "movie" is the same.
AM radio: OK, no issues.
CD player: OK, no issues.
Idrive not exhibit weird behavior when the problem happen.
Old 10-08-2012, 10:36 AM
Mein Auto: BMW 745i
Sounds like radio tuner issue
Old 10-08-2012, 02:36 PM
i thought so too...but i took out my tuner (its the one behind l c pillar on the drivers side right?) nd opened it up...a classic smell.test for burnt parts revealed no issues...nd from what i could see with my limited knowledge everything was in good working order so i put it back together. the static still.exists.
Old 10-08-2012, 04:19 PM
Mein Auto: BMW 745i
Classic smell Really??? So you think if smth goes bad it should smell and show signs of burned and damaged parts?? It's XXI century btw life would be too easy if you could find faulty modules by smelling them
So you said cd plays ok no static at all? Bc if there is its your ask unit. If static is only on FM it's your tuner or antenna on the back window, try to disconnect the wide connector from tuner module, and check for static.
Old 10-09-2012, 06:22 AM
as i said..my knowledge is a bit limited.i scanned the car using autologic, and inpa.no faults stored.
but as far as i know...if some.electronic part is blown it should make an awful smell right?
anyways...i did check the connections and as far as i can see, there's nothing broken including the wires in the rear glass.
so i'm a bit stumped. i still wanna try disabling the booster via ncs and see how that goes.
Sent from my GT-P6800 using Bimmer App
Old 02-14-2013, 12:31 AM
jassoo jassoo is offline
Mein Auto: BMW 745iA
I have also this same problem with radio.
90% of time it doesnt work as it should.
I use only FM-radio and we dont have any AM-radio here in sweden.
sometimes radio wont find any radio-channels at all and if i it finds "volume" is low compared to CD. Sometimes radio "volume" goes up n down.
Does anyone have a clue what is it? Antenna, Radiotuner or what??
I have changed ASK-module (speakers crackling noice) and radio didnt work with old ASK and not with new one so its not that.
Old 02-14-2013, 01:30 AM
let me know how u fix that
