E60 (2004 - 2010)
Old 05-02-2012, 08:54 AM
joe1351 joe1351 is offline
Mein Auto: 528i
Is it possible to install the inbuilt BMW navigation system
Recently I bought 2009 528i that came with premium package. Although the car does not Navigation it does have option on the idrive . So my question if I want to install navigation what are the things I need to buy to make it happen? Cost?
Joe
Old 05-02-2012, 10:27 AM
2chill's Avatar
2chill 2chill is offline
Mein Auto: 2008 528XI
You are looking at thousands of dollars in parts and labor. Not really worth the money and effort. There are many threads on this board about people who want to add Nav to their E60. You can do a search. I don't understand when you say you have the option for it on the Idrive. The car should only say "Car Data" where the Navigation option should be. What does yours say?
PP, CWP, NAV, satelite radio, USB, Folding Rear Seats.
Old 05-02-2012, 04:23 PM
Mike_K Mike_K is offline
Mein Auto: 6 Speed 550i Sport
I don't believe the above post is accurate at all. You can get the CCC navigation system for under $1000. Install it, code it, call it a day. I've done a lot of reading on this because I have a non-nav car and I bought it only because I had plans on upgrading to the newer CIC system. Even that system can be had for around $1500 now.
Old 05-02-2012, 04:39 PM
drlarryg drlarryg is offline
My car has the Nav. It's not worth it. I would save your money. Just my opinion.
Old 05-02-2012, 06:41 PM
mjsbmw's Avatar
mjsbmw mjsbmw is offline
Mein Auto: 2010 535xi
I can only give the other view. The integrated feature of how the navigation operates is worth a reasonable cost. Not spending an additional 3K. It might not be a perfect system but my 2010 535 Nav works great.
Old 05-02-2012, 06:54 PM
sockmonkey sockmonkey is offline
Tail out!
Mein Auto: BMW
You may be hopeful, but are equally unrealistic. I'm a pretty good shady tree mechanic, and fixed UH60s when I was in the Army. I researched this carefully before I bought, and as a result made sure that I bought a car with the nav system.
$1000? C'mon man. Not going to happen. New screen, new interface, nav computer, DVD player, new center console faceplate, GPS antenna, wiring harness, patch into CANBUS harness and coding? For a grand? Negative, even for a DIYer.
For $2000 it could be done, but it would be an unbelievable pain in the a**.
Old 05-03-2012, 11:52 AM
Mein Auto: 528i
Thanks everyone for the inputs. I will be checking with the dealer soon on this. Will comeback and update what I hear.
Old 05-03-2012, 11:53 AM
PimoX3 PimoX3 is offline
Mein Auto: 2008 550 m-sport, 2006 X3
It's been done many times... check out threads on 5series.net
As mentioned above, $1000 is pretty optimistic and would realistically only be possible with used parts.
These days, the big mod is to install the CiC based navigation with all of the fancy new features.
Old 05-04-2012, 09:44 AM
heffdiddy's Avatar
heffdiddy heffdiddy is offline
Mein Auto: 550i; 335i Sedan
if you have the option in idrive then you should have it. unless they changed in 2009. do you have a second cd slot below the audio cd slot?
if you dont have it i wouldnt worry about it. it wouldnt be worth the cost for the little benefit it provides. you have to buy new discs every couple of years and it is kind of a pain to put addreses in. its much faster and more accurate to use your phone, provided you have a smartphone.
BMW 545i-Sold
BMW 650i-Sold
BMW 335i-Current
BMW 550i-Current
navigation
