E34 (1989 - 1995)
Old 05-02-2012, 10:02 AM
system2007 system2007 is offline
Mein Auto: 1994 BMW 530i
Electrical!!! Ooh noooo :(
So the other day I noticed that my license plate light warning had turned on. I took a look but my lights were still so I followed the wires til I found some cut and some frayed. ( they were in the trunk and looks like they got severely pinched) so being the idiot I am proceeded to touch and wiggle the wires they sparked so I left them alone til the next day when I was able to splice all the wires. (I actually did a good job ) but now my Dome lights don't work, my windshield wipers don't work, my power locks don't work, and my winds and sunroof don't work either. Any ideas? I need help. I don't want to spend an arm and a leg to fix it unless I have too.
Old 05-02-2012, 10:29 AM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: M50 Big Body
well, when you went all:
(LOL )
You probably shorted a few fuses. Check the fuse box to try and find any blown fuses
1995 525iA 250k mi Shifted Performance E34
2006 325i/6 48k mi
2003 350Z 87k mi Shifted Performance 350Z
Garden State Euros
Old 05-02-2012, 10:52 AM
jfs356's Avatar
jfs356 jfs356 is offline
Mein Auto: 1994 530i
No doubt one of those wires is tied to the locking system which you shorted out. Probably one fuse controls all the items that are failing now.
Old 05-02-2012, 11:15 AM
When the wires touched I did hear the locks lock everywhere. But I checked all the fuses and the only ones that showed they Wernt getting any juice were the headlights and those are working
Old 05-02-2012, 12:46 PM
supertech777's Avatar
supertech777 supertech777 is offline
Mein Auto: 1995 525i
How about the power distribution box under the back seat by the battery , you should check those . I believe its all tied in that box .
Sent from my Desire HD using Bimmer App
Old 05-02-2012, 01:08 PM
I checked the fuses around the box but not in it. I will take a look when I'm back to the garage and tell you my findings.
Old 05-02-2012, 05:16 PM
jfs356's Avatar
supertech77 is right, there are a couple of fuse blocks in battery box that tie everything together. Look especially at fuses 17, 24, 30, 31 and 47 as they are part of central locking, windows, sunroof interior lighting and wipers.
Old 05-02-2012, 05:30 PM
So I replaced two fuses and now everything but the dome lights work. So I called an auto shop and they said they don't work on BMW. A customer overheard the phone conversation and asked them to give me his number he said he knows a lot about electrics on mostly boats but he loves BMW also and he works on them. So I gave him a call and he lives near by so he stopped in and took a look he said the only thing he can think of is the timing relay. Does this sound like an possible problem?
Old 05-03-2012, 06:00 AM
jfs356's Avatar
If everything else works, I would check the bulb in the light to make sure you did not blow it. Not sure about a timing relay, will have to look at the manual when I get home this afternoon. Dome lights are switched so that you can have them come on or stay off when the car door opens.
Old 05-03-2012, 07:09 AM
+1
