Old 05-02-2012, 01:26 PM
lilwhtbeamer lilwhtbeamer is offline
Mein Auto: 528i
What all engines can fit my 97 528i?
Will an engine from an e34 525i fit into my e39 528i?
What all engines are compatible?
Old 05-02-2012, 01:54 PM
Blauanzug Blauanzug is offline
Mein Auto: 2003 525i
Um why would you want to do this?? The engine computer systems changed from the e34 to the e39 and it is more difficult to retrofit an e34 into an e39. Why would you want to put an older engine into the car?
Old 05-02-2012, 01:56 PM
manticore33's Avatar
manticore33 manticore33 is offline
Send a message via AIM to manticore33
Mein Auto: '86 Porsche 951, '01 530i
Unless you have time, mad skills, and money, the engine that is compatible with your car is the engine is in the car.
I like coffee.
My e39 is fixed and moving towards atrophy.
Old 05-02-2012, 04:11 PM
Mein Auto: 528i
True that. I dont want to put an older engine in my e39, i just dont know what kinds of engines would fit.
help?
Old 05-02-2012, 06:42 PM
the540wgn's Avatar
the540wgn the540wgn is offline
Mein Auto: '02 540iT
this one
my wagons faster than yours
Old 05-02-2012, 07:19 PM
Fast Bob's Avatar
Fast Bob Fast Bob is online now
Keeping it surreal
Ls-1....
The road goes ever onward....
(R.I.P. Jever)
*Please support the Wounded Warrior Project*
Old 05-02-2012, 09:32 PM
gary@germanautosolutions's Avatar
gary@germanautosolutions gary@germanautosolutions is offline
Mein Auto: 528-530 Hybrid, Duc. 748
The '97-'98 528i's have the M52 engine. In 1999 it changed to the m52-tu which added dual VANOS, DISA valve and other electronic changes. Trying to swap anything other than an M52 will cause more problems than it's worth.
Gary
"I'm a little rascal on my Little Rascal"
- unknown
Old 05-03-2012, 05:37 AM
granlund granlund is offline
Mein Auto: 2002 530i
What about an S52B32 then?I know it's not the cheapest option, but can the DME be made to work?
Old 05-14-2012, 07:05 PM
kmorgan_260 kmorgan_260 is offline
Mein Auto: 2007 335i
Similar question. I am considering buying a nice '98 528 with a blown motor. I have a M52B28 from a '98 328i that I assume would go in without much trouble or I might want to try finding an M62 which I also assume would fit. Not sure it would mate with the tranny though. It has the 5 speed manual and I think the 540i came with the 6 speed. Anyone know if I can use the M62 on that tranny?
94 318i, 97 528i, 07 335i
Old 05-14-2012, 09:03 PM
eparayno's Avatar
eparayno eparayno is offline
Mein Auto: 2001 530i
What engine would fit but for what reason? If you have the dough you can put whatever damn engine you want.
Old 05-14-2012, 10:38 PM
Silver540i6 Silver540i6 is offline
Mein Auto: BMW 540i/6
If I was going to spend a bunch of money trying to put a v8 in it, then I would definitely be putting a ls1 motor under the hood.
1998 BMW 540i/6 Sport...18" Staggered M Pars, Angel Eye Upgrade, Muffler/Resonator delete, iPod integration kit
1970 Dodge Challenger R/T SE...440 six pack, slap shift...blows away all e39s
Old 05-14-2012, 11:49 PM
Darren1231 Darren1231 is offline
Mein Auto: 2001 e39 525i
It's a bit blasphemous but why not implant a 2jz-gte or an RB26-dett N1 in her since money is no issue? I mean why else ask the question if you have unlimited resources, right? Better yet, throw a Nelson Racing Engine on that hoe and rock 1500WHP!
Old 05-15-2012, 11:29 AM
Turbo_525 Turbo_525 is offline
Mein Auto: 2002 525i 5-spd
Or just try this one:
  • N/A 525i, 5-speed, 138+K
  • BMW's are not like other cars, they have issues and cost you real $$$ to sort.
  • Affording to Buy a BMW is not the same thing as affording to OWN a BMW.
  • Pre-Purchase Inspections by a qualifed BMW tech should be considered required PRIOR to purchase.
  • Service Records matter - a whole lot!
  • Plan to spend $2-3000+ in maintance & repairs the first year of ownership.
  • Plan on something unexpected to happen, more often than you are used to.
Old 05-15-2012, 12:37 PM
Not sure how we got off on a tangent about money not being an issue, but if that were the case we certainly wouldn't be discussing this in the e39 forum. Lets face it that is why we are all here.
Old 05-16-2012, 11:42 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
The I6 & V8 e39s not only have different transmissions...but also do NOT share the same front suspension.
The V8 e39s (M62 & M62TU engines) have the old recirculating ball front suspension because there is not enough room in the e39's engine bay design for the updated rack-n-pinion front suspension that the I6 models got.
So installing a BMW V8 in an e39 6 cylinder model would require a complete different front suspension as well as transmission & rear end.
And as someone already mentioned...the easiest replacement engine is the same one being replaced...and in this case it's the M52 engine. If you don't know which BMWs used this engine...a simple internet search (wikipedia for instance) will reveal what other BMW models (and any other car model) used the same M52 engine. This will also include the engines displacement (B28 in this case).
FYI: one must also consider other BMW technology like EWS. One must consider the original DME since it has a coded ISN (individual serial number) that must match the other EWS components in order for the vehicle to start. So swapping in an entire engine & management system from another car can be fraught with issues if the other EWS components aren't brought over with the engine & engine management systems...but this is only an issue if one is not keeping the original engine management system.
Q {BMW CCA Member #191509}
(SOLD)
Old 05-16-2012, 01:56 PM
Thanks for the good technical info. I am closing the deal on the car tomorrow and my plan is to put the M52 from my donor 328i in it. I am told I will have to swap the oil pans but otherwise it should be straightforward. I will use the DME that is already in the car so the EWS should be happy. Will post pics when I get it home.
Old 05-16-2012, 01:57 PM
BigCo540i's Avatar
BigCo540i BigCo540i is offline
The Usual Suspect
Mein Auto: 98 E39 540i
This would be a good question for Bimmerforums.com
