Crossed Drilled Rotors - Bimmerfest - BMW Forums
E46 M3 (2001-2006)
Old 05-02-2012, 03:38 PM
2MCHM4U 2MCHM4U is offline
Mein Auto: e46 ///M3
Just looking for suggestions on where to buy. Im looking at front and rear and dont want the oem zcp as they are out of my price range. unless you guys know where i can get a good deal on them. Thanks
Old 05-03-2012, 06:05 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
Why do you want them?
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 05-03-2012, 09:50 AM
riviera1969 riviera1969 is offline
VELOZV
Mein Auto: 2008 BMW 335I STICK SHIFT
I bought some
Check this out and also they have different ones I bought a set for about $200 all four with ceramic pads included. Check this wweb site:
http://www.ebay.com/itm/PREMIUM-SERI...10ce9e&vxp=mtr
Old 05-03-2012, 10:15 PM
Mine are worn out.
Old 05-03-2012, 10:26 PM
Mine are worn out.
Old 05-04-2012, 06:47 AM
Pinecone's Avatar
M Mad
Just wondering why cross drilled. They really don't do anything, other than for looks. And can resultin cracking of the rotors and fasterpad wear, but not as bad as slotted.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 05-08-2012, 08:15 AM
ECSTuning's Avatar
Instructor of the Stig™
Do you have a ZCP already or a standard M3? If the later then you might want to check out our new ECS GEOMET Rotors (found HERE) for the E46 M3.
Customer Service Hours: M - F 8:00am - 8:00pm EST | Saturday: 10:00am - 7:00pm EST
Sales Team Hours: M - F 8:00am - 11:00pm EST | Saturday: 10:00am - 7:00pm EST
800.924.5172 | OEM BMW Part Number Search
Old 05-08-2012, 01:12 PM
VELOZV
They brake better
I really fill the difference and I don't get brake dust on my rims is like 99% less dust. The stock rotors last about one and half brake pads so is about the same with the ones I got for alot less.
Old 05-15-2012, 05:49 PM
mwhiteknight mwhiteknight is offline
Mein Auto: 05 m3 05 545i
I have the zcp brake upgrade on my car and it is amazing. I did not know when i order that it is bigger rotor than regular so it like you have big brake kit upgrade. It feel a lot stronger than stock and I can lock up the brake almost any time I want. The stock brake barely lock it. You will love it
Old 05-16-2012, 08:10 AM
VELOZV
I didn't get bigger rotors and they still brake alot better not like the bigger ones but still. If you do go with bigger rotors you also will need to change the calipers.
Old 05-16-2012, 10:53 AM
No need to change caliber, the ZCP kit come included with bracket to move the caliber out further to fit bigger rotor.
Old 05-17-2012, 07:44 AM
VELOZV
That is great stuff that is why I'm part of this forum.
Old 05-17-2012, 07:48 AM
ECSTuning's Avatar
As long as it's an upgrade kit not just the rotors. The ZCP/CSL carriers relocate the caliper so it can handle the 345mmx28mm rotor.
Old 05-17-2012, 08:21 AM
that is correct, you have to buy the upgrade kit to receive the bracket . Also the ZCP rotor is floating 2 piece rotor which will help reduced weight and run cooler than stock. Much better than stock and brake fade is almost nonexistence . Stock rotor is 1 piece.
Old 05-17-2012, 10:11 AM
Pinecone's Avatar
M Mad
I find brake fade to be non-existant with the stock setup. Even with street pads driven reasonably sanely on the track.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
