Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - F01 (2009 - current)
The new re-designed 7 series leads off the BMW Fxx chassis code!
Old 05-03-2012, 09:28 AM
gsimpson7 gsimpson7 is offline
Mein Auto: 2009 BMW 750LI
265-30-22 front and rear
Has anyone put 265-30-22 on front and rear of a 750LI instead of going staggered?
Old 05-03-2012, 04:33 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
depending on the on the offsets, you may run into some rubbing while turning in the front, and on the rears they should be okay, just it may look a little odd because its slightly narrower than the factory tire.
My suggestion is to go with 255/30/22's on the front and 295/25/22's on the rears, much more aggressive stance!
Old 05-03-2012, 07:52 PM
265 30 22 is the suggested size for the front. I was going with the same on the rear to eliminate the staggered bigger but thinner tire on the rear which is a 295 25 22.
