E34 (1989 - 1995)
Old 05-03-2012, 05:10 AM
dwhite993 dwhite993 is offline
Mein Auto: 95 BMW 525i
lower control arms
So my 525 was shaking a lot between 55 and 65 MPH. I put it on a lift and saw it needed lower and upper control arms. Yesterday I put lower control arms on, not upper yet, and now it drives with less vibration and is much sturdier but it drives like a truck the steering sways a lot and at lower speeds I can steer all the way to the left or right and let go of the wheel and push the gas and it will just keep steering that way with out turning back. What's going on?
Dakota
95 525i 180xxx "The Green Hornet"
Old 05-03-2012, 06:57 AM
measuringtape measuringtape is offline
Mein Auto: 1991 BMW 535I
ive never run into this issue myself but i would say finish up the upper control arms and then try and diognose the problem, it could be the the worn ball joint binding in some way.
Old 05-03-2012, 07:11 AM
Yeah that's what I figured OK I'll do that and leave feedback
Dakota
Old 05-03-2012, 07:12 AM
awesome!
Old 05-03-2012, 04:47 PM
could it be idler arms? as well.
Dakota
Old 05-06-2012, 04:28 PM
Weisebar Weisebar is offline
Mein Auto: E34 525i
Have had this issue before but not on a BMW. First drive after replacement, I nearly ran into a light pole because the steering was so tight. After a bit of use though, all loosened up. Give a little use and see if it does.
Cheers
Weisebar
Old 05-10-2012, 07:33 AM
TemporarySanity's Avatar
TemporarySanity TemporarySanity is offline
Mein Auto: 02 530, 02 540, 07 525
Did you have the full weight of the car on the arms before you tightened them? Common mistake. The car can not be in the air when you tighten the arms as it will stress the bushings when you lower it back down. Not sure that it causes steering issues though.
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot.
